Great job, I like the old twisted sticks.
__________________ peglegcanes.embarqspace.com |
#12
Nice the way that you 'enhanced' the natural topography of the wood, super colors! A shame about that 'weak spot' at the bend at the tip, though (unless its 1 1/2" thick...). I have had to reject so many fantastic stix just because the 'good stuff' didn't quite reach the ground. Sometimes I was able to 'fake it' with a long ferule and bolt (and plenty of epoxy). With all the manzanita around here, I have the same problem, a very 'angular' growing wood, beautiful, but finding a usable piece of the appropriate length is quite the chore. I had a bit of a 'crook' on the bottom of one, once, and was able to strengthen the bend by inserting a piece of threaded rod (after drilling a hole!) that extended a couple of inches on either side of the bend (and double dutied as the tip that hit the ground). |
#13
| Quote:
__________________ My chainsaw carving and woodworking videos: http://www.youtube.com/user/Mueiwark WCI Gallery: http://tinyurl.com/yfvoyq7 |
#14
Although crooked stix have their beauty, as long as the pressure on a stick is compressionary down the center axis, any deviation from that axis is necessarily a 'weakness'. At the bend, the tendency is to 'bow' (and eventually 'snap') where the tendency in the straight stick is to compress, enabling it to remain in one piece where with the same pressure the 'bow' will snap. So there is 'weakness' but that weakness might never be manifested under 'normal' use. I might emphasize the 'strengths' and 'weaknesses' a bit more than canes solely for simple perambulation, as the canes that I make are designed to remain intact should the need arise to use one to adjust the agressive attitude of a misanthropic gorilla! Yew is a hella strong and tough wood and I'm sure that there would be no problem under 'normal' conditions. |
#15
Just lovely. Nice use of the pretty, pretty yew. And... hella elastic, too... the stuff of the famous Welsh longbow. makes me wonder what bamboo would be like for carving. I digress... really is a pretty stick!
__________________ "Beauty will save the world" - Dostoevsky www.JenkinsLovespoons.com http://blakespa.blogspot.com http://davidwestern.blogspot.com |
| Man with cane | windsong | Flat Plane Carving | 18 | 07-11-2009 11:33 AM |
| Mtn.. Man Releif aspen cane (Finished carving) | Mark Gargac | New Projects and Works in Progress (WIP) | 9 | 07-28-2008 05:30 PM |
| Cane | Doug Ridley | General Wood Carving | 5 | 07-23-2008 11:51 AM |
| Dragon ship cane finished. | squbrigg | General Wood Carving | 36 | 05-04-2005 11:24 PM |
| al's Twisty Aspen Cane Finished | AlArchie | General Wood Carving | 15 | 12-21-2004 11:13 AM |
