Power Carving
Old 04-21-2008, 11:17 AM
Default Tool Review? Mastercarver ProFlex
As I mentioned in Dean's thread I have a Dremel Flex Drive unit.
And I am sometimes impaitent when I have a lot of material to remove.
The limitation of the Dremel is that it only uses 1/8 & 3/32 burrs.
I have been wanting to get a machine that would take 1/4" cutters.
And am looking at the Mastercarver ProFlex machine.
I have considered a pneumatic die grinder, but don't always want to deal with the compressor(already have a compressor) noise.
Anyone have one and could you give me your impression?
Old 04-21-2008, 02:59 PM
susieq
Default Re: Tool Review? Mastercarver ProFlex
Although I have never had the Mastercarver ProFlex, I have only heard good things about it. I do own one of their micromotors and for the money, it's a great tool. I do think you would be happier with one of the larger flex shaft tools at this point in your carving. I have a couple, the large Dremel which is not made anymore, and an old Foredom. 10 years old, that I got new and have used hard. It still runs great as does the big old Dremel.
I think all 3 of these brands larger shaft tools are quite comparable, quality wise. It is nice to be able to put a 1/4 " shaft kutzall or carbide cutter into one and really "hog" the wood.
susieq
www.susanmattix.com
Old 04-21-2008, 10:49 PM
Thanks Susie
Old 04-22-2008, 06:49 AM
squbrigg's Avatar
Foredom has a handpiece that takes 1/4" burrs and plenty of torque to turn them. I find them a bit too aggressive for me, as I don't have much strength in my hands, and it does take strength to hold and guide those big burrs to get the best results out of them. They do make a heavy job a lot shorter, they will remove a tremendous amount of wood, very quickly. You may want to consider upgrading to a Foredom unit at some point.
link to Gallery photos
Old 04-22-2008, 08:41 AM
I have the Master Carver Pro Flex tool and am very happy with it. The receprocating handpiece works well. The smaller handpiece is great for getting into tight places. The 3 Jaw Chuck on the standard handpiece takes up to 1/4 inch.
I am ordering the foot control today. I bought it as a table top model and now know I like the foot control better.
I used the unit for a solid week taking one of David Sabols power carving classes a couple of months ago. I had no problems with it and have used it quite a bit since then with no problems. I believe it is rated at 1/3 hp. I think that is quite a bit more than the Foredom. I also have a Foredom and have used it for years. I bought the Master Carver because of the HPower.
Steve
www.birkes.com
Old 04-22-2008, 09:17 AM
Steve, The 1/3 HP rating was one of the reasons I was considering the pro-flex. Being left handed I do need a reversible unit.
Interesting that you mention the reciprocating handle, since I was debating whether to get the two handpiece model or the package with additional reciprocating piece. I was a bit skeptical till I read that it would accept the flexcut blades. I think you have pushed me over the top on this decision. The wife and I have sometimes each been working on our own projects at the same time, and while after 36yrs we do share well, it would be nice to not have to wait your turn.
Old 04-22-2008, 09:49 AM
Bob it is hard to debate the reliability of the Fordom units. They have been around forever, there are thousands in use, and they pretty well set the standard by which all others are measured.
I grew up in the 50's & 60's and kind of have that Tim the Toolman mindset"More Power!"
Even if the HP of the powerflex is overstated(not uncommon in advertizeing) it's a big step from 1/10Th HP to 1/3 rd HP.
Since I'm not sure which direction this carving thing is going to take(Fish,wildlife and decoys or smaller characatures and sticks?), I think I would prefer to go overboard on power, as to discover later I need more and underestimated my needs.
Old 05-18-2008, 07:20 PM
telecarver
I have the Mastercarver ProFlex and have used it extensively. It is superior to the Foredom because of the higher RPM. It comes with handpieces that take 3/32, 1/8 and 1/4" bits. My only complaint, and this is a significant one, is that the reversing switch is easy to flip too far when turning the unit off so that the reverse is activated and the tool sounds and feels like it's going to blow up when it changes direction instantly while the tool is still spinning in the other direction. So far it doesn't seem to have harmed the tool by doing this but by the way it sounds and feels, it's hard to imagine that some damage isn't taking place. That said, the tool works great for power carving. Just make sure that you take extra care to touch the switch very slowly when turning it off. I prefer to use an independent electronic speed control instead of the foot pedal. This allows more freedom of movement when working on larger projects.
Regarding pneumatic die grinders, I have several and they work well. They require a very large compressor. A minimum of 10 CFM is necessary for most pneumatic die grinders to run at full power continuously. I don't use them much because it seems very inefficient to run a compressor that takes 20 to 30 amps of power to do the same job (almost) that you can do with a 3 amp electric tool.
Fordom vs Mastercarver larrydm Power Carving 4 08-26-2007 03:10 PM
Suggestion for a review, Foredom 1050 Micro Motor squbrigg Power Carving 8 07-27-2007 02:29 PM
Bandsaw Review Article Claude Woodcarving Tools, Technology & Sharpening 4 10-16-2006 10:10 PM
problem with Mastercarver tool madmangil General Wood Carving 42 06-25-2006 12:56 PM
Fox Chapel Publishing Book Review Mottles Author questions 0 10-17-2005 01:47 PM
Santa Carving Contest
