Power Carving | |||
I don't do alot of power carving, so this works for me. A small window fan with variable speed control. I attached a 10" x 20" furnace filter to the back. I can hold the project 8" to 10" away and it does a good job, and alot quieter than a shop vac. With the variable speed I can dial the speed down for hand sanding. I already had the fan so the cost of the filter and I am in business. Randy |
I use a fan also,I use a box fan with a couple regular fiberglass filters to catch the course dust and a pleated filter like you use next to the fan.With that setup I can go longer between filter cleanings.Just wish my fan was variable speed like your setup. Tony |
Good idea Tony. I'll add a couple of fiberglass filters to this one. Randy |
Randy, It seems like you should have a shroud around where you are carving, so it will concentrate the air flow a little more. A cardboard box would do. Nice simple idea you have. Tom |
| Quote:
. I made mine using a 120 v dimmer switch. It's mounted inside a square metal switch box and has a 15 inch piece of electric cable and plug. This cable is plugged into a live circuit to power the dimmer switch. The dimmer switch and a female plug unit are wired and mounted inside the metal box. Your fan is plugged into the female plug on the unit. You'll have to drill the correct size hole in the metal box plate. The dimmer switch's shaft will go thru that hole and the knob attaches to the shaft. Do a search for the correct wiring sequence. |
Thanks for the idea Randy, Where can you get the filters? Alex |
| Quote:
Randy |
| Hey Alex, I bought mine at Home Depot. It's a regular furnace filter. Randy |
| 75.00 lap top dust collector | sccarnes | General Wood Carving | 7 | 10-22-2009 10:35 PM |
| DC-725 Dust Collector | Reyn | Woodcarving Tools, Technology & Sharpening | 0 | 05-22-2009 01:55 PM |
| Need Dust Collector Help! | Bob Tamillo | Power Carving | 15 | 04-06-2009 11:39 AM |
| Poor man's sandpaper cleaner | DICK "chipncut" CAIN | Wood Carving Tips and Techniques | 8 | 05-27-2006 08:34 PM |
| Dust collector | FINGERS | General Wood Carving | 6 | 04-13-2005 10:08 AM |
