Power Carving
Old 07-10-2010, 05:10 PM
Donsexton's Avatar
Default My Way
I wanted to show how I carve the wing tips on my eagles its a very fast way. I shape them with a chainsaw and grinder then break out the grinder with the saw blade on it. I also wanted you all to see how I carve a log to look like rocks first deep cuts with the chainsaw then a ¼” die grinder with a Saburrtooth bit. This is that cherry eagle I started a few weeks ago I have not been able to work on it until today.
Old 07-10-2010, 07:11 PM
Default Re: My Way
Thanks Don, I like "Your Way"... Gonna have to try the small saw blade after seeing your last couple of posts!
Steve
My website
Harrison Game Calls
Old 07-10-2010, 07:29 PM
Mark N. Akers's Avatar
Default Re: My Way
Don:
looks real nice, can't wait to see it finished.
Old 07-11-2010, 12:11 AM
Donsexton's Avatar
Default Re: My Way
Steve
Steve make sure you have the guard in place and in the correct position and wear heavy leather gloves. If the blade gets in a bind and you turn it loose watch your feet.
Old 07-11-2010, 12:03 PM
Default Re: My Way
Yeah it does look like one of those "Total Focused" tools... Thanks for the tips.
Steve
My website
Harrison Game Calls
Old 07-11-2010, 05:18 PM
Thor's Avatar
Default Re: My Way
Thanks Don. Geez, now I need a die grinder.....
I'm going to the Buzz in the Blue Ridge next weekend, and really "watch" the tools and techniques being used. I can't afford to buy stuff I won't use a lot, so I'm slow at the changes.
Your technique looks scary to me with the small saw blade on the grinder. I was using my grinder with the flappy sand paper, and burned a nice indentation through my glove into my finger yesterday. It never even hurt...sort of cauterized as it tore I guess, but kind of put a damper on the progress for a few minutes. I thought I WAS paying attention.
I like the way you do rocks. I have a drawing that will need some soon...and may put that into use.
Thanks again for the step by steps. I know they take time and effort.
Christina
Old 07-11-2010, 07:04 PM
Donsexton's Avatar
Default Re: My Way
Christina you will have a great time at that event and see some talanted carvers. I know you will see how they use die grinders. Most dont like my use of saw blades on grinders like I say its my way, not for every one. It is fast!
Old 07-12-2010, 03:00 PM
Default Re: My Way
Where is this event...Buzz in the Blue Ridge?
Old 07-13-2010, 09:06 AM
Thor's Avatar
Default Re: My Way
Buzz In the Blue Ridge
Hosted by the Habersham Winery Helen GA
Fri-Sat July 17th-18th 8.30am-5.00pm
Sun July 19th 12.00pm-5.00pm
Old 07-13-2010, 11:25 AM
Sharon of the Dell's Avatar
Default Re: My Way
Don, what kind of saw blade do you use on the angle grinder? I don't think I would try it, just curious! I have an Abortech pro carver(?) with the 3 carbide cutting tips on my angle grinder. I haven't used it to much. I've practiced on tree limbs and roughed out a few spoons with it, it's a 2 handed tool, so I put the limbs in a vice.....Christina, I have a GDO800C makita die grinder and some kutzall burrs, it has 6.5 amps, like a dremel on steroids. It's one of my favorite power tools. Don't get the cheap one, because it only has 2 amps.My dremel 400 has 2 amps for comparison. Buzz in the Blue Ridge sounds like great fun! You are fortunate to be able to attend. I hope you take lots of pictures and post them here. Enjoy your weekend there!
