Power Carving | |||
How do you get the background(deepest level) level? I'm using a dremel with sort of an egg shaped burr, but I can't seem to get all of the background evened up. Also, the pattern is a Celtic knot and I would appreciate any advice on cleaning up the very tiny crevices. I'm using red oak, hoping to use the board for a crosspiece on a piece of furniture. Thanks.
The only way that I would know how to level the background would be to use a depth gauge. You can make one with a 1/2" square piece of wood that's long enough to span the carving plus about 6". Drill a hole in the center and thread a screw in to touch the deepest part of your carving. Use that to help determine how much wood you need to remove from other parts of the carving. I hope this explanation makes sense and is a help. Michael |
I have used an carbide inverted cone to do some cleaning work and then use a green stone to sand it down.. It is very hard to get a perfectly flat area in the tiny spots so I just try to make the Celtic work look REALLY good so you don't have to work so hard on the background. I have been putting a slight pattern into the back to give it more interest and it keeps me from having to get it perfect. |
Thanks for the replies! It's my first relief carving, so it's going to be a good learning experience.
In the "Cleaning Out Corners" thread, several suggestions came up to deal with the "fuzzies.". 1. Very pointy knife and a dental pick. 2. Small diameter punches made from nails. 3. Some sort of a handle with a 1/16" (or smaller) drill bit in the end. I tried them all. For me, the drill bit suggestion worked the best in Western Red Cedar. The fuzzies are soft and hard to take a bite out of. Some Dremel kits have small diameter drill bits. |
| First Relief Carving | dalboy | Relief and Chip Carving | 6 | 01-22-2012 06:39 PM |
| Article discussion thread:2010 Best Carving Design Contest: Relief Carving Division Winners | WCIarticleBot | Publisher Feedback | 1 | 12-10-2010 10:33 AM |
| First relief carving | Fred Eberle | Power Carving | 11 | 12-24-2009 12:39 PM |
| 1st relief carving-need help | Micky | Relief and Chip Carving | 15 | 10-06-2006 10:00 PM |
| Relief Carving | Guest | Relief and Chip Carving | 0 | 03-29-2003 12:55 AM |
