Power Carving
Old 06-20-2010, 10:58 PM
Just Carving's Avatar
WhittleBear Carver
Default Air Hammer with air compressor
Any thoughts or tips on using an air hammer with modified chisels for roughing out logs?
I know Elwood Troll uses modified chisels--drills a hole in the handle of a full size mallet tool, cuts off the working end of the chisel, epoxies the remander of the shaft into the handle, and inserts the shank end in an air hammer like typical air chisel. I'm curious as to what PSI to set the regulator on a compressor, and as I said any other comments or experiences in using an air hammer in wood carving.
Thanks
Bob L
Old 06-21-2010, 06:07 AM
Donsexton's Avatar
Default Re: Air Hammer with air compressor
I modified some air chisels re forged and ground the cutting edge for wood. I thought I would like it for fast roughing on large carvings. For me it was not as fast as I thought it would be not as fast as a chainsaw. I still use it when I want to remove the bark from logs I want to store.
Old 06-21-2010, 09:13 AM
WhittleBear Carver
Thanks Don. Can you tell me what pressure you set your regulator at--90 PSI?
I'm curious to find out if modifying a full size chisel or gouge like what ElWoodTroll (see link) would work for me in carving logs.
http://www.woodcarvingillustrated.com/forum/f67/air-tools-14546/#post128303
Bob L
Old 07-20-2010, 01:19 PM
Hi Bob I have used an air hammer for a long time I use a muffler chisel to remove bark set the regulator so the hammer just removes the bark and feels good to you good luck------Jack
Old 07-20-2010, 01:42 PM
WhittleBear Carver
Thanks Jack. Any recommendations on a compressor? I don't have one and figured I'd get a cheappy just suitable enough to use the chisel with and blow off chips/sawdust.
Bob L
Old 07-20-2010, 05:04 PM
Donsexton's Avatar
I adjust the air by the feel and the way it cuts as well not over 80
Old 07-21-2010, 07:48 AM
WhittleBear Carver
Thanks Don. That helps. So, now I know I need a compressor set at about 80 PSI using 4 CFM.
Bob L
Old 08-09-2010, 12:07 PM
Bob L dont buy a cheap compressor if you can help it go to sears and get a quick recover----Jack
Old 08-10-2010, 08:03 AM
WhittleBear Carver
Ok Jack I hadn't given thought to the recover time.
Thanks
Bob L
Viking relief - hammer SeanMcD New Projects and Works in Progress (WIP) 20 12-07-2009 03:58 PM
Compressor size Royal7777 Wood Carving for Beginners 9 11-22-2009 11:30 PM
2-3 Gal Air Compressor less then 90.00 GIOUA Woodcarving Tools, Technology & Sharpening 3 03-04-2009 10:38 PM
Compressor noise fix jartzh General Wood Carving 3 08-04-2008 03:47 PM
