Old 04-09-2008, 10:29 PM
tucker1931's Avatar
Default Re: Smiling Eyes, Flat Plane Style
Mike, this is what I call a tutorial, I'm with you 100% on these close ups, I'm sure we will all benefit from this as we go along, thanks so much buddy.
Cliff
Old 04-10-2008, 12:22 AM
Iowa Carver's Avatar
Looking good Mike! Thanks for the tutorial!
Corey
Old 04-10-2008, 02:43 PM
gene messer's Avatar
Great job Mike ... keep -em coming ..
Gene
G.M.
Old 04-10-2008, 05:24 PM
Marci MN's Avatar
*sitting here with carving in one hand, knife in the other.. poised.. ready for intermission to be over* Oh I'm liking this tuturial... I so want to learn how to do faces better...
Old 04-10-2008, 06:21 PM
Mike_B-NY's Avatar
Gene,
Hope you don't mind me stepping on your "flat plane" turf. Your stuff is awesome. They're gonna be my next carvings after I finish this project.
OK Marci... here we go("intermission" was me going to that darn "day job")
16. We're basically going to repeat that first wedge cut, this time for Santa's brow. About a third of the way up from that horizontal line you drew last, to the brim of Santa's hat, line the blade up parallel to the horizontal line and press a cut in and under the line. The knife should be tipped approximately 45deg from vertical. Do you notice I use a lot of "about", "approximately", and fractions? This ain't rocket science Folks... eyeball as much as you can... nobody is going to check your measurements and angles later... and this is not a test.
17. This is how it should look at the end of this cut. If you can't make this cut, don't worry. Start closer to line and do Step 18 closer to the line and gradually work your way out in both directions, getting deeper as you go. The other possibility is that it's time to sharpen your knife... go ahead... we'll be here when you get back and I won't tell .
18. Go below the line about 1/2 of the distance to your first wedge cut and cut in and under to the horizontal line. The knife needs to be tipped down this time, further from vertical than the cut in Step 16 (trust me... it's geometry).
19. This is Santa's brow. Again, don't sweat it if you can't cut this wedge out with two strokes... I'm probably just showin' off. Start with a small wedge on the line and work your way out in both directions and deeper untill it looks something like this.
20. Knives down, pencils up! Draw a square top "A" centered on the... well, centerline, and taking up the whole distance between Santa's brow and the top of his 'stache. This is Santa's nose. Slant the sides of the "A" and change the size of the flat top to make his nose broad and wide or thin and narrow to taste. You might want to skip ahead and preview our next cuts, because the nose will end up slightly thinner that it appears here(WARNING: Objects in mirror may appear closer...).
16.smiling-eyes-flat-plane-style-se-santa-step16.jpg___ 17.smiling-eyes-flat-plane-style-se-santa-step17.jpg___ 18.smiling-eyes-flat-plane-style-se-santa-step18.jpg___ 19.smiling-eyes-flat-plane-style-se-santa-step19.jpg___ 20.smiling-eyes-flat-plane-style-se-santa-step20.jpg
Old 04-10-2008, 07:04 PM
BasketballJones's Avatar
Yep enjoying it as well. Kind of a cheap thrill for me bet not too many know where Rome is. Glad somebody's still working there. Hope the snow melted. Thanks for doing this.
Humor Heals and when spread can be infectious.
Old 04-10-2008, 07:53 PM
tucker1931's Avatar
Hey Mike, I've got a hell of an idea, you should make a video of this carving and sell it, you'd probably do real well with it. (is that a snide remark?)
Cliff
Old 04-10-2008, 09:11 PM
Mike_B-NY's Avatar
Lol, Cliff... don't go "there".
Keep on Carvin'
Wooden Dreams Woodcarving
http://www.woodendreamz.com
Old 04-10-2008, 10:22 PM
Mike_B-NY's Avatar
21. You need to wedge cut out both sides of the "A", but because of obstacles this probably can't be done with two cuts, so... reach up from the mustache and wedge cut the top half of each side, then...
22. ...turn Santa upside down and, reaching down to the mustache, get the bottom of each side of the "A".
23. ...and this is what it looks like upside down...
24. ...and right side up.
25. OK, knife down, pencil up! At the bottom of each leg of the "A" there are new corners now. Mark small triangles off each of those corners. There should be four.
21.smiling-eyes-flat-plane-style-se-santa-step21.jpg___ 22.smiling-eyes-flat-plane-style-se-santa-step22.jpg___ 23.smiling-eyes-flat-plane-style-se-santa-step23.jpg___ 24.smiling-eyes-flat-plane-style-se-santa-step24.jpg___ 25.smiling-eyes-flat-plane-style-se-santa-step25.jpg
Old 04-10-2008, 10:58 PM
Very cool Mike. Thanks for doing this!
Corey
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f64/smiling-eyes-flat-plane-style-16894/
Woodcarving Illustrated Message Board This thread Refback 04-09-2008 12:46 PM
what is flat plane? rickm Caricature Carving 4 01-01-2008 08:47 PM
Please help with carving Smiling Eyes Ventoux_Carver Wood Carving for Beginners 10 12-27-2007 05:42 PM
Carving A Little Guy Face In The Flat Plane Style gene messer Wood Carving Tutorials 24 12-11-2007 12:26 PM
Flat Plane Santa gene messer Holiday 18 10-12-2007 03:22 PM
Would these be considered flat plane? brushpilecarvings Caricature Carving 6 05-16-2007 08:18 AM
Santa Carving Contest
