As we start this new section you may want to read through the entire posting to at least step 230. As I have worked this stage I chose to roll over or curl one of the leaf edges on the face of the carving. That's shown in steps 221 through 230.
I did only one edge but you might have a lot of fun rolling or curling over several of your leaf edges. So, read through this stage first then decide which edges you want to roll .... you can roll every one if you want and it would make this carving outstanding!
But ... I am only rolling one edge because of the number of photos it would take to roll them all
Step 212: I am ready to clean up and smooth out the back of my carving. So I start by finding items to prop him durning the work. I have my white erasers back on the bracing board and I have added some foam backed sanding pads that I keep for this type of situation. The pads are placed face down, sand paper side down, onto the board or table with the project resting on the foam side. The sand paper side grabs the work surface
and the foam side pads and grabs the wood. Those little pads offer a lot of holding power.
Step 213: I am smoothing out the gouge ridges with my bench knife and chisel. As I am working I decided to widen the curve areas on the back. That will make larger cast shadows on the wall later. Wide curves make wide shadows - sharp short curves make small shadows.
You want both wide shadows and small shadows in a relief carving. Don't get carried away and make every curve a wide one.
Step 214: The chip knife will go right into that tight curve we made with the band saw at the beginning cut out stages.
Step 215: To taper or smooth out the tight band saw curve I have grabbed my large round gouge. I am using it in a half circle cut that starts high on the wall of the band saw curve and ends low to the inside of that curve. In the phot you can see the comma cut just above where the gouge tip is ... that's the half circle cut.
Step 216: Once I have the curve opened with the large round gouge I use my chisel to do the final smoothing. I could also have used my wide sweep gouge for this smoothing step.
So, a quick review for these steps ...
1. Chip knife or bench knife to widen the back areas.
2. Chip knife to open and clean the band saw curves.
3. Large round gouge to widen the band saw curves.
4. Bull nose chisel or wide sweep gouge to smooth everything.
