Step 200: I am using my v-gouge to dress out, smooth, the remaining intersections where the stem and leaf meet. This is any area that has not been under cut.
Step 201: The left side done I am moving into the right side of the leaf. I don't want
to coup out here because this started with a request to show everything!!! But I am not going to show you each and every step through this area. As a left hander that particular portion of the project is braced in the corner of my bench hook. So to work
that area I have to turn the piece so that the beard tip is now the bracing point. That leaves the left stem area at the bottom of my board where my camera can not possibly go ... the corner of the board is the edge of the table so my camera keeps falling over ... AHHH!
And I am not going to do unsafe carving by trying to hold it while I cut. So far
this has been a blood free project and I, for one, would like to keep it that way
So for the right side of the leave I am doing exactly the same thing I just showed you
on the left side except for a couple of steps ... those I will show you.
The first is that I have lots of room for a very deep under cut on the leaf where it
lies on top of the center stem. I already have a small angle from the earlier rough out work, but I want to really tuck that area.
Step 202: I have marked where I want to put that under cut. Notice that I have left
more than half the thickness above the under cut. Then after this is done I will have room in the leaf wood to roll that top shelf over into a nice curve.
Step 203: This will probably be the deepest under cut that I do on the Oak Man so I am walking the chip knife into the depth by making several cuts ... not one deep push.
Step 204: Because this is a bit of a stickler of an area to get into I did not make the second cut of the under cut. Instead I grabbed my chisel and sliced out the wedge in little pieces. In very hard to reach areas I get the same effect using the chisel, it takes a little longer but is much easier to work.
