Wood Carving Tutorials | |||
Ok .. So here goes .. Another project for beginners .. A simple Hillbilly out of a block of wood ... But this one is a little bit more of a challenge for the beginner .. A figure with a hat ... So Iam going to make it as simple as possible .. So please bear with me because there are 60 photos involved where the last tutorial was 46 photo's .. I hope all you beginning carvers get some kind of help from this .. Good luck .. The entire figure is carved from basswood with only a knife and a small v-tool .. So here goes .. Gene 1. The Block ( 1 inch x 1 inch x 6 inches high ) 2. Draw for hat .. measure 1 1/2 inches from the top of the block and draw a line in the front of the block .. Turn over to the back of the block and measure 2 inches from the top of the block and draw a line .. connect the lines as in photo on both sides .. 3.Separate the hat from the body .. 4.In the front of the block . measure 2 inches down from the top of the hat and draw a line for the bottom of the beard .. 5.From the bottom line of the beard . on both sides of the block draw a line connecting the back of the hat to the bottom of the beard as in photo ..
__________________ G.M. |
6. Separate the beard from the body on all sides .. 7. Measure up 3/8 inch from bottom of block and draw for shoe's .. 8. Separate feet from body .. 9.Side view of beard and feet cut's .. 10. Begin to shape back of hat ..
11.Shaping back of hat with v cut's ... 12. Shaping side of hat with v cuts... 13. Shaping front of hat with v cut's .. 14. Shaping the face for nose .. 15. Drawing the nose ...
16.Cut for nose ... 17.Shaping the nose ... 18.Drawing the mustache .. 19.Cutting out the mustache .. 20.Drawing to separate the beard from face ..
21.Cut to separate beard from face .. 22.Front view of beard and face ... 23. Shaping front of body ... 24. Shaping side of body .. 25.. Drawing for right side of arm ...
26. Shaping the front of the arm .. 27. Drawing for arm in back of figure .. 28. Cut for back of arm ... 29.Drawing for hand ... 30. Separating hand from arm ...
31. Drawing for left side arm .. 32.Under left arm cut for back of arm .. 33. Shaping the front of arm .. 34.Cut to separate hand from pocket .. 35.Draw and cut for back of arm on figure ..
36. Drawing for back of pant leg's .. 37. Cut for back of pant leg's ... 38.Drawing to separte pant leg from shoe's .. 39. Cut to separate pant leg from shoe's .. 40. Drawing to separate shoes ..
41.Cut to separate shoes ... 42. Drawing to separate front pant's leg's .. 43. Cut to separate front pant's leg's ... 44.Cut to separate belly from leg's .. 45. View of leg and belly cut's ..
46.V cut's to get wrinkles in pant's .. 47. Shaping hat with v cut's .. 48.Shaping back of hat with v cut's 49.Shaping front of hat with v cut's 50. Cut v cuts for facial eye's ..
| "Carving A Simple Small Figure From A Block Of Wood '' A Beginners Tutorial | gene-messer | Wood Carving Tutorials | 72 | 01-15-2012 07:19 PM |
| Gene's "carving simple small figure tutorial" | Jaysonmol | Caricature Carving | 2 | 08-24-2007 02:37 PM |
| Yay! New Carving Tools and a Block of Wood! | knightflight | Wood Carving for Beginners | 32 | 12-11-2006 05:48 PM |
| One Block Two Wood Spirits | Mottles | Wood Carving for Beginners | 17 | 11-21-2005 04:34 PM |
| Frustrated with a block of wood! | Chahlie | Carving Wood & Materials | 7 | 06-23-2004 12:20 AM |
