Old 04-15-2009, 11:52 PM
Default Sweet Potato Carving
Anyone know what kind of finish I could put on a sweet potato I carved?
Mike's Carving Corner
-Mike
Check out my website
carvingcorner.com
Follow me on twitter
twitter.com/stxcrvr
Old 04-16-2009, 08:46 AM
Default Re: Sweet Potato Carving
Butter? Salt & Pepper?
Out West Woodcarving Blog:
Out West Gallery
Old 04-16-2009, 03:19 PM
JJireh's Avatar
Wood...
Nothing can preserve the potato for long.
Old 04-16-2009, 03:29 PM
Hi Mike,
I did one last year and didn't put a finish on it all. It has a bit of black in spots, but hey ... it adds to the character.
I will try to take a photo tonight and post it.
Brent
Old 01-21-2012, 05:19 PM
motleyjust's Avatar
It helps if you put some kind of coating on it, to keep the sweet potato from re-hydrating.
I made some sweet potato kazoos. After they were completely dry, I coated the inside with beeswax and the outside with a mixture of beeswax and turpentine. I used beeswax to protect and form the mouth piece and to stick the membrane on.
Pictures01
They are about a year old. I need to give the outside another coat and add more beeswax to the mouth and resonator hole, because it has worn off from handling.
Old 01-21-2012, 05:23 PM
Terry Vance's Avatar
"Old" Guy
good answer. I got a good laugh out of that reply....
Keep carvin'
God bless you,
John 3:17
http://www.picturetrail.com/terryvance
my WCI gallery
Old 01-21-2012, 06:56 PM
Whimsicalcarver
I carved a Santa and dried it in the material you get from the craft store. It works wonderful. You use a container just sized to fit the potato then pour the crystals over, cover and let sit for a week. Then use acrylic paints and when dry spray with a clear gloss finish. Perfect!
Old 01-21-2012, 08:41 PM
motleyjust's Avatar
I believe you are referring to silica gel. I never thought of that. It would speed up the process a lot.
I have tried accelerating the drying process on some by using a very low oven with the door propped open. I'm not sure, but it may have affected it adversely.
I'll have to get to a hobby shop and get some.
Old 01-24-2012, 12:52 PM
motleyjust's Avatar
I made a special trip to Micheal's yesterday to get some silica gel. When I got home and opened it, it was the kind with an indicator added. I might use it if I do some just carvings, but since it is a skin and eye irritant and harmful if swallowed, I obviously can't use it on kazoos. I did look on the package before buying, but there is so much writing, in several languages, in several bright colors, I couldn't find the part that said that.
I will have to try to find some plain silica gel.
I wonder if a carving dried with the indicator kind is even safe to be handled.
Old 01-24-2012, 01:07 PM
Place the carving on a piece of screen just above the silica gel in a jar with a tight fitting lid.
Let it sit. When the gel changes color, replace it. Rejuvenate the hydrated gel in a very low oven, it will change color back to indicate "dry" .
Oddly, there is still enough water in the gelatin of analog photographic films to raise Hello in a high vacuum situation. So, we had dessicators all over the lab with boxes of film over silica gel. After that, the film boxes went into a vacuum dessicator which was pumped out. In the bottom for a drying agent was phosphorous pentoxide (and that really was nasty.)
Sweet bay Magnolia Lonewolfcarver Stick and Cane Carving 11 02-26-2009 11:51 PM
Shannon's Little potato Keoma Publisher Feedback 2 11-20-2008 10:47 AM
Just like Lay's potato chips you can't have just one! agaboric General Wood Carving 2 08-25-2008 11:36 AM
Sweet Gum wood suz_es General Wood Carving 2 09-03-2007 09:15 PM
Carving Sweet gum green. Mike-in-WV General Wood Carving 12 08-12-2006 09:56 AM
