Old 05-04-2008, 05:11 PM
Default Re: samples are done
I don't have the right expression, Mark only, WOW you are so talented
Alice
Old 05-04-2008, 08:34 PM
Claude's Avatar
Originally Posted by mark yundt View Post
...Yes Claude,,I like my design better as well. But even though the architects might by comparison look ho-hum,,that is what it should look like. In the recent discussions on Critiquing,,here would be a possible problem. Though it might not look as impressive as the other,,and you know it isn't as fancy as you know I might be able to carve it..it is just what the design called for. Could I have carved it better,,and should I? Should I ignore what the design calls for and add my own particular flourishes that might improve it,,or do what others feel would help it? Is it a good or bad carving? It's neither,,it is what it is supposed to be. Just sort of ho-hum,,,and that's only because of a direct comparison. On it's own,,in the right setting,,it will look just fine.
I understood. The workmanship on the architect's design is great - it's the design that's lacking, in my opinion. As Doris says - it doesn't lead the eye around (boring). I think you did the correct (right) thing by carving the design as given to you; then you carved (spent your valuable time) on an alternate design that can show the architect a better (my opinion) design. And I have to disagree with your last statement: I think the architect's design will still be boring, even in the right setting...a back-of-the-envelope sketch is still a back-of-the-envelope sketch, even if was hanging in the Louvre...
But, that's only my opinion...
My web site
Old 05-04-2008, 09:07 PM
mycarver
Ahhh,,,Claude,,,you're a man after my own heart! LOL...LOL. I knew you understood,,but in my own clumsy way I was trying to be gracious. You're a very intuitive man,,insightful,,and wonderful! And I too share your feelings about the piece. But who knows,,maybe that's what he really wants to see. I'll find out shortly ,I hope,and let you know.
Thanks!
website at
www.woodworkingstudio.net
e-mail to
mycarver@rcn.com
Old 05-04-2008, 09:20 PM
mdallensr's Avatar
Very nice work, Mark. Your design really flows yet is vigorous. Lot's of interest and very well executed. I know the feeling about continuing to mess with it, but it really won't get much better than it is now. I nitpick them to death, way past the point of diminishing return. Thanks for showing us how to do such a great job so quickly. Mike
Old 05-04-2008, 09:26 PM
mycarver
Mike,,,coming from you,,that means so much! Wow,,,,
website at
e-mail to
mycarver@rcn.com
Old 05-05-2008, 11:08 AM
Ashbys's Avatar
Mark ,
I look at the two designs, and I go back to working with the right side of the brain.
The designs are both good , but for the application , your will work better. You made yours opened , flowing and living, by using the frame effect it makes it look larger and more open , it should increase the effect of making the bed look larger.
The first design , is closing, tight , confined restricted. I think in the setting of wanting something to appear smaller , or safer it would be a very good pattern. It could eaisly be used in combination in a room to highlight a single piece of furiture. It could be used to shrink a dresser to make it look smaller, then the true size. The combination of the designs could eaisly do that.
Ash
Ash
Old 05-05-2008, 12:34 PM
mycarver
Plus..his design is only a segment of a larger whole.The entire design might very well be quite nice.
website at
e-mail to
mycarver@rcn.com
samples mark yundt New Projects and Works in Progress (WIP) 24 05-02-2008 06:17 PM
Santa Carving Contest
