| Found the Fox?
02-15-2008, 05:04 PM
|  | web site coming soon | | Join Date: Sep 2007 Location: Fort Peck Indian Reservation, Northeast Montana.
| | A Little Help This is my next project and I would like to know if anyone has a way to clean out the area at the neck and hair line without power? I can never get it as clean as I like it. I am sure the way to do it is to keep going down in size with V tools and gouges but just wanted to know if anyone has a better way.Thanks Vince |
02-15-2008, 05:31 PM
|  | Senior Member | | Join Date: Aug 2007 Location: Ontario Canada
| | Re: A Little Help Hi Vince, lookin good there buddy. I'm not a very experienced carver as you know but, I would suggest a set of Rifflers (I think Smoky Mountain has them) thay are inexpensive and come in a set of 12 or so and they're all different shapes. Hope this helps.
Cliff |
02-15-2008, 11:03 PM
| | Re: A Little Help Well here is where I am at right now. It takes a while to get here but I guess thats just the way it is till I find or make the tool or tools I need to do what I am after. Vince Thanks for lOOking |
02-15-2008, 11:48 PM
| | Re: A Little Help Well I don't know how ya did it but it looks like the people from Gillette must have dropped by with some new spiffy razor. Whatever ya did it sure looks good now.
Cliff |
02-16-2008, 08:16 AM
|  | Senior Member | | Join Date: Jan 2006 Location: New Glasgow, Nova Scotia Canada
| | Re: A Little Help I have two bent gouges that I use in spots like that. What ever you used, you took care of your problem as I can see his adam's apple sticking out and the musculature showing on other side.
He's got a good strong chin which phases into his neck...not an easy task. What wood are you carving? I like the grain of the wood.
Patrick |
02-16-2008, 10:37 AM
|  | Senior Member | | Join Date: Jan 2007 Location: northern germany
| | Re: A Little Help no special tools needed...mostly you can do with a number 2 in approriate width (or similar shalow gouge), cutting from two sides, and if the meeting should be not sharp, you can use a u-gouge going over it, and nicely blend the lines in... |
02-16-2008, 02:14 PM
| | Re: A Little Help Thanks for the info. I do not have any thing more shallow than a #3, guess I will just have to get more tools. Now here are the pics before BLO. Vince
02-16-2008, 02:30 PM
| | Re: A Little Help These are the pics after oil. Patrick the wood is a piece of cottonwood about 5" by 12". It is very dry and very very soft. If tools are not like razer blades it will crush and tear. I use it to practice on until I get good enough to not trash something better. There is a lot of it here so thats what I use for now. The other choice is ash, just the opposite. Very hard. Thanks again for looking and your comments. Vince |
02-16-2008, 04:24 PM
|  | One Chip At A Time | | Join Date: Aug 2007 Location: La Porte, Indiana
| | Re: A Little Help Great job! Like the others said, whatever you used worked very well. Just keep chipping and eventually, somehow, it seems to turn out. Looks very good.
Dan |
02-16-2008, 04:29 PM
| | Re: A Little Help # 2 and # 3 might be same, depending on the numbering system your gouges use... i guess #3 is fine anyway, the point is, it should be very shallow, only not strictly flat...if it is a little curved, you just need make a few more cuts... th carving turned out nice, whatever your problem had been... really like it :-) | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -4. The time now is 02:20 AM. | |
