| Found the Fox?
02-14-2006, 01:23 PM
| | Maker of fine shavings | | Join Date: Jan 2006 Location: Rose Valley,Saskatchewan, Canada
| | First Kolrosed spoon done!!! Well after making my 2 new Kolrosing knives, I had to apply the technique to a project. Since this is my first try at this way of decorating a piece, I used/copied alot of Judy Ritgers pattern she used on a similar spoon. It is a valentines spoon carved from a piece of birch, I free handed the pattern then did the kolrosing. Once done, I rubbed very fine ground coffee into the incisions and layed on a coat of boiled linseed oil. This was not easy to do with no tutorial to follow, so I had to learn as I went. I hope that with practice my next project will be more intricate and free flowing, without the jagged edges. Hope you like.
CHEERS....
Harley
02-14-2006, 01:35 PM
|  | Senior Member | | Join Date: Nov 2005 Location: Glenwood, MN
| | Re: First Kolrosed spoon done!!! oh ya.. I like!! Beautiful! |
02-14-2006, 01:57 PM
| | Re: First Kolrosed spoon done!!! good job! I like it. I haven't tried kolrosing yet, but probably will ..............  |
02-14-2006, 02:58 PM
| | Re: First Kolrosed spoon done!!! Thanks folks, I plan on doing more, it's fun, but hard on the fingers.
CHEERS....
Harley
02-14-2006, 03:28 PM
|  | Member | | Join Date: Mar 2005 Location: SD
| | Re: First Kolrosed spoon done!!! Very nice! |
02-14-2006, 06:32 PM
|  | Senior Member | | Join Date: Feb 2002 Location: Calgary, Alberta, Canada
| | Re: First Kolrosed spoon done!!! Great job Gilly!...very nice piece...just curious about the staining with coffee...doesn't it tend to stain the rest of the surface or do you sand or rub it off? |
02-14-2006, 07:29 PM
| | Re: First Kolrosed spoon done!!! Its coffee grounds Bandaid, you just rub them into the cuts...... haven't done it, but read up on it some time back.  |
02-14-2006, 07:47 PM
| | Re: First Kolrosed spoon done!!! Quote: |
Originally Posted by Bandaid Great job Gilly!...very nice piece...just curious about the staining with coffee...doesn't it tend to stain the rest of the surface or do you sand or rub it off? | The idea is to allow the grounds to lie in the grooves, then brush off the excess and oil or wax over top, then allow to sit to give the coffee time to work-in. In this case, the coffee ended up tinting my oil but gave a nice light color, so my mistake, worked out in my favour
CHEERS....
Harley
02-14-2006, 08:28 PM
| | Senior Member | | Join Date: Dec 2004
| | Re: First Kolrosed spoon done!!! Gilly,
I have made a few spoons over the years and I have to say you did a fine job on the bowl.
I have never tried it, but I wonder if an engraving pencil would work for putting in the lines of the pattern. |
02-14-2006, 09:08 PM
I have never tried it, but I wonder if an engraving pencil would work for putting in the lines of the pattern. | I thought about that, like an engraver for marking you property, I have scribed into wood before using these, and it seems to work fine, but in this case, I "had" to make 2 kolrosing knives therefore I "had" to use them to decorate a spoon.
CHEERS....
Harley
Similar Threads | | Thread | Thread Starter | Forum | Replies | Last Post | | Spoon | Scotty Dog | Wood Carving for Beginners | 12 | 08-11-2006 11:42 PM | | spoon in progress | Thor | New Projects and Works in Progress (WIP) | 8 | 10-18-2005 09:51 AM | | spoon carving | Dennis Taylor | Wood Carving for Beginners | 30 | 08-29-2005 08:17 PM | | spoon patterns | Dennis Taylor | General Wood Carving | 1 | 07-19-2005 10:24 PM | | spoon making | jordan | Wood Carving for Beginners | 5 | 03-25-2004 02:32 PM | All times are GMT -4. The time now is 10:11 PM. | |
