Steve Brown Woodcarving
Old 03-30-2012, 04:03 PM
pararaptor's Avatar
Default Doin' a Mermaid Kinda Thing part 2
Hey Everyone,
I'm attaching a few pictures of the mermaid project so far.
I used some pearlized blue and a little green airbrushed on and wiped off a few times to get a stained effect that allows the wood grain to show through, and I attached a mermaids body and splash parts out the end of the bore.
If anyone's interested, I'll post a sequence of photos showing the transition from carved wooden mermaid, to the casting resin model.
This is the way the flute looks at the moment. However, I'm making a short series of cast resin mermaids to emerge from and plunge into the surface of the flute, with water splashes along the way, like a pod of dolphins.
Greg
Old 04-02-2012, 01:51 AM
Sharon of the Dell's Avatar
Default Re: Doin' a Mermaid Kinda Thing part 2
Greg, it's coming a long wonderfully!
I'm really interested in your casting process from wood to resin.
I did lost wax casting (in silver) in high school and really enjoyed it, even though I could only get one piece that way. Casting is something I'm very interested in.
Old 04-02-2012, 06:21 AM
That is amasing Greg. I love seeing your flutes and would realy like to see how you went about this one Its something else.
Keep them comming mate
Cheers
AL
Old 04-02-2012, 02:44 PM
mpounders's Avatar
I would be interested in seeing your process also. The splashing water too!
Mike P.
"Life is a song, sing it!"
Mother Teresa
Old 04-02-2012, 05:32 PM
Josef's Avatar
Timber Torturer
Magnificent as always. Loooking forward to the progress. Joe.
I'd rather have a bottle in front of me than a frontal lobotomy.
http://carverjoe.weebly.com
Old 04-23-2012, 01:16 AM
pararaptor's Avatar
Wellllll now.....I'm glad you all are interested.
I've been away for awhile because there were no replies to this project and I inferred from that that no one was interested in the project or the process.
Now that I see I'm wrong, I'll post some pictures of the process. It was actually quite easy!
I first need to remind that though it's a cast piece at the end of the flute, it's only because I first carved it in wood..
Check back and I'll have a photo series and description. I highly recommend taking a stab at this process too.
Greg
Old 04-23-2012, 02:05 AM
pararaptor's Avatar
First of all, I had an image in mind after having seen this carving tutorial, and this tutorial on carving water splashes I envisioned a mermaid with more flowing hair, so I modified the pattern.
Old 04-23-2012, 02:09 AM
pararaptor's Avatar
I then took the pattern and re-sized and remapped the features I wanted to change. I then carved a mermaid from Alaskan yellow cedar and painted it white to reveal places that needed emphasis and other places to remove more wood.
Old 04-23-2012, 02:15 AM
pararaptor's Avatar
I then made a mold from Apoxie-Sculpt, and subsequently made another one from "Amazing Mold Putty" that worked out much better.
When the cast resin mermaid dried; I sprayed some adhesive to some wedding veil, and applied some gold leaf through it to give a semblance of scales.
I then wadded some plastic wrap and poured casting resin over it to make the water splashes, and tied some knots on monofilament and dipped it in resin for further splashing water effect.
Old 04-23-2012, 02:24 AM
pararaptor's Avatar
By this point, I had a customer who wanted it, and he wanted a series of waterine looking mermaids going in and out of the surface of the flute like a pod of dolphins (it isn't something I would have done for myself, buuuut....customer's always right).
So I made several more mermaids and cut some to appear emerging and others to be diving along the surface of the flute, with their own respective water splashes.
Doin' a mermaid kinda thing pararaptor New Projects and Works in Progress (WIP) 3 03-11-2012 05:37 AM
New kinda project for me cut up New Projects and Works in Progress (WIP) 13 11-07-2011 06:57 AM
Doin' the right thing Soggy Caricature Carving 18 01-15-2011 05:54 PM
Here's What I've Been Doin' schooner Wood Carving for Beginners 19 07-08-2009 09:45 PM
I Kinda Did It! Lindy Off Topic 6 03-19-2008 06:09 PM
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
