Old 06-06-2010, 11:03 AM
Default Burner and tip
See the earlier pst on the Northern...thes are the shots of the burner I use.Here's the burner I use for scales. I made up about 4 or 5 different sized tips fpr differernt fish.. the cheap-o hobby burner works great for scales.
Old 06-06-2010, 11:46 AM
btree50's Avatar
member
Default Re: Burner and tip
Thanks for the idea! I like the scale burner,
JimB
Old 06-06-2010, 12:42 PM
toycarver's Avatar
Girl Carver
What type of metal do you use to make your tips?
Kris
WCI gallery:.
Old 06-06-2010, 01:05 PM
Kris, those are made from brass rod. Mostly I use 1/4" stock. the threaded end is turned down to 3/16? then threaded at 8-32. If I want a 1/4" dia scale I simply drill a 3/16" hole about 1/4" deep in the end then using a coutersinkg cutter, cut into the hole till it makes a sharp edge with the outer circumference. After that i take a file and remove half of the 1/4" end, leaving a half circle with a sharp edge to it.
If I want smaller scales, I turn the 1/4" stock down (after cutting the threads) down to the diameter I want, drill it out with a smaller diameter drill land then cut with the countersink bit.
Larger scales, like for a carp could be made by using 5/16" or 3/8" brass rod. the threaded end always has to be turned down to thread to 8-32 (at least for this burner. some burners have a larger male thread on the burner and accept a larger female cut tip. you'd have to do a lot more turning to get one of these to work, and be able to cut intermnal threads on the scale tip. I wouldn't try that.
My tips take about 15 minutes or less to make and cost virtually pennies, compared to the Colwood scale tips for the pro burrners.at 8 to 20 bucks
Old 06-06-2010, 01:57 PM
toycarver's Avatar
Girl Carver
Al, that is more than I figured. I was thinking maybe you just cut up an old soup can and bent it around or something! Your answer sounds more logical though.
Kris
WCI gallery:.
Old 06-06-2010, 02:02 PM
You can also "carve" those scales in, using a small half round veiner. Simply press it intothe wood. Or make a scale press from small steel tubing, available in most hobby shops. Put a lenght of tubing in a drill and file the edge sharp, then filehalf the tube away.. Press this sharpenwd edge into the wood.
New Burner samuraifly Pyrography and Woodburning 16 05-10-2009 09:41 PM
A Incense Burner big dave Caricature Carving 16 10-20-2008 05:08 PM
New Burner Laura Redfern Pyrography and Woodburning 19 09-18-2008 08:46 AM
which burner do you use? susieq Pyrography and Woodburning 13 03-03-2008 05:55 PM
New Burner Hanna Pyrography and Woodburning 11 03-09-2007 04:40 PM
