Originally Posted by hruukki All you need with gouges is: keep your both hands behind the cutting edge and always carve away from yourself.  |
Well, when using Palm tools, I find it works best to rest your elbows on your legs, so you won't be using any shoulder or upper arm movement, and then using your wrist only, with the gouge pointed at you, proceed to cut wood. If you don't use your arms or shoulders, you can't move the gouge close enough to you to hurt you. I usually wear a leather shop apron, just in case.
I agree with hruukki, though, about the full sized gouges: best to not have your body in line with the cutting edge
when it slips, because it will slip.
Mischief: Personally, I prefer non-folding knives. My favorites are the Flexcut knives, because they feel very comfortable in my hand, and they hold an edge quite well. My detail knife is a Bütz knife because of the the long skinny and thin blade. Most pocket knives have a blade that is way too thick for wood carving. If you have a Woodcraft or other woodcarving store anywhere close by, go in and hold several knives and see which one feels the most comfortable. Most Woodcraft stores will have a few pieces of wood you can use to test-carve a knife or gouge. Your other option is to go to the Little Shaver's web site
http://www.littleshavers.com/BegKit.html and buy a Beginner's Set from Rick. It comes with a knife, some sharpening stuff, a set of palm gouges, and even a carving safety glove. And it all comes SHARP! Go to the Search function above these words and type in "Beginner Set" and see what the rest of the forum members say.
<edit>
Ooops - missed the photo of the kit in the background. Sorry about that - you're way ahead of me on that one.
</edit>
