Old 02-16-2011, 10:24 AM
Default WATER SPLASHES
Hello This is woodcarver. I'm new to the group and anxious to get involved. I like to carve fish, marine mammels and water related stuff. I understand you cannot use "plastic" water splashes for competition; however, for display purposes I would like to try to make some. Any recommendations on technique, material, resources, etc? Thanks.
Old 02-16-2011, 05:50 PM
Kev.b
Default Re: water splashes
Hi Dennis if you can get hold of "wood carving" magazine ( a GMC publication) No.118 Jan/feb 2011 on page 50 there is a very good tutorial of a leaping trout complete with "water" feature made from resin. the water effect and carved trout are very good.
I can pm you the write up if you like but its pretty comprehensive
Everything we hear is an opinion, not a fact. Everything we see is a perspective, not the truth.
Marcus Aurelius (Emperor of Rome 161 to 180)
Old 02-17-2011, 03:19 AM
chipmunk's Avatar
Default Re: WATER SPLASHES
u could carve and paint or use a acyclic of a blue,green u may beable to use a epoxy[thick coat ] pour on finsh let it set abit then mould to get the look u want it's used to make running water or drops it's thick and clear
Old 02-17-2011, 08:30 PM
Dileon's Avatar
I know an artist in Kauai makes ocean waves with epoxy, first you have to make a master mold and then a latex cover and plaster mold covering, next pour epoxy in it. A note ...this is an expensive project and will need some experimenting. First time they did the model, it was not banded and they had a nice epoxy floor. As for color you would need a hole in the bottom in which you would pour your color which would reflex the color plus the color from your base.
DiLeon
water splashs and water using resins Terry General Wood Carving 5 12-14-2009 02:18 PM
Over water/under water relief carving Gray_Fox General Wood Carving 3 11-22-2004 06:57 AM
water dropplets/splashes Guest General Wood Carving 3 03-14-2004 09:46 AM
