Old 07-21-2008, 04:07 PM
spot
Send a message via MSN to sccarnes
Default using super glue to reinforce cross grain?
guys, i think i saw an article in wci, where the carver used super glue to get wood ready to cut, made glass frames stronger, so could cut face away from glasses.
my question is,
carving a horse, and using 1 solid block of basswood, when i get to the final stages, on the legs and knees, if i soak the small cross grain area, with super glue will it make it stronger,
and will i be able to paint,
guesso does OK, but i was thinking , super glue might make it stronger,
but if making it stronger, affects the paint, might not be worth it,
anyone used approach?
thanks.
sam
Old 07-21-2008, 05:33 PM
Plain_Ol_Ed's Avatar
Default Re: using super glue to reinforce cross grain?
I've used that technique quite often and it works well for me. It does show slightly through watered down acrylics, but if you are currently using gesso under your paints it should not effect it at all (or for that matter just full strength paints). Most people don't even notice it under watered down acrylics unless they know where to look. Try it on some scraps first.
e.v.olson@att.net
Knife Collection
Try Open Office, It's Free
http://www.openoffice.org/
Old 07-21-2008, 08:35 PM
Super glue is the way to go to reinforce crossgrain when you're out on the small edge of something but I don't think I would rely on it for something like a leg. It would be best to pick up a long drill, available at most home stores, and drill a hole for a wooden dowel. You can use a syringe to shoot glue down the hole just make sure you drill completely through so the excess glue has somewhere to go when you push in the dowel. Let the dowel stick out the back-end too so you can carve it off.
This might sound a little involved but if you have a carving you really want to last it's the only way to go.
Old 07-21-2008, 09:51 PM
Claude's Avatar
Originally Posted by Lynn O. Doughty View Post
... It would be best to pick up a long drill, available at most home stores, and drill a hole for a wooden dowel. You can use a syringe to shoot glue down the hole just make sure you drill completely through so the excess glue has somewhere to go when you push in the dowel. Let the dowel stick out the back-end too so you can carve it off.
If you can't drill all the way through, an alternative method is to drill the hole as deep as you can, and then carve a flat on one side of the dowel to give the glue an escape path. As you push the dowel into the hole with glue in it, the excess glue can flow out between the side of the hole and the flat and can be easily wiped off.
My web site
Old 07-21-2008, 11:58 PM
mdallensr's Avatar
We've used super-glue to harden bird's beaks and tail feathers. Be careful about woodburning super-glue though; it has a cyanide component and the fumes aren't good for you. Mike
Old 07-22-2008, 06:32 AM
spot
thanks for the replys,
most of my legs are less than 1/8 to 3/16 inch thick and bend at the knees,
am not that good with a drill to trust my self to get centered.
could always do the add on legs, but then i could never do a show, sorry lynn, couldn't help myself,
will try and see, thanks
sam
Old 07-22-2008, 08:28 AM
mdallensr's Avatar
With legs that thin, try the super-glue. When the add-on parts are small, I've been using brazing rod or some other stiff metal rod instead of wooden dowel rods.
Old 07-22-2008, 06:38 PM
William's Avatar
The super glue works good but be sure all of the carving is done before you apply it because it's like carving stone after.
Old 07-24-2008, 06:23 PM
oldbearx2's Avatar
There used to be a product out there by Minwax called Wood Hardener. It was used to harden up rotted wood prior to using their Bondo type wood filler. I wonder if it is still around and it it would work?
Harold
Old 07-24-2008, 07:03 PM
It is, and it doesn't. At least not as well. Doesn't seem to penetrate the way super glue does.
e.v.olson@att.net
Knife Collection
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f60/using-super-glue-reinforce-cross-grain-18345/
Woodcarving Illustrated Message Board This thread Refback 07-22-2008 09:52 AM
Protecting wood with Super Glue kitaye Wood Carving for Beginners 11 12-17-2007 02:15 PM
Super Mouse sludgeguy Caricature Carving 8 11-12-2007 01:15 PM
super glue on the thin stuff cedarshavings Wood Finishing and Painting 8 03-17-2007 06:40 PM
Cross grain carving on basswood. jerry_k General Wood Carving 9 10-24-2004 10:48 AM
Super Glue Guest Wood Carving for Beginners 16 09-11-2004 05:19 PM
