Old 01-02-2012, 07:38 PM
Default Re: Using Super Glue?
When gluing back a small area I use Elmers glue and put a small dot of super glue in the middle.It makes it stick fast,especially if you can't clamp the piece in place.
Old 01-03-2012, 05:01 PM
Beginning Carver
Originally Posted by Dileon View Post
Some great points made .....they are all going into my journal.
Journal??? What a priceless idea!!!
LMiller
Old 01-08-2012, 01:06 AM
autobodyman's Avatar
I've used CA glue about 1/2" inside the perimeter of two pieces of wood I wanted to glue together with wood glue everywhere else, press and hold for 60 seconds or so the CA (superglue) holds the pieces together while the wood glue dries overnight. Works really well for pieces that are hard to clamp, though I usually use medium CA glue because the thin stuff sets to quick for me.
~Mike
If at first you suceed, try to hide your astonishment.
Old 01-08-2012, 06:53 AM
STAR's Avatar
What a super idea, never thought of that, I make a few toys each year and enter in our local Agricultural Show. that idea is priceless. I have plans for a Kenworth Prime Mover and large trailer. It will be carrying something I will carve.
There are a lot of small pieces to fiddle with and the super glue and yellow glue is tops.
Pete
Old 01-08-2012, 09:52 AM
Just remember.....when using carpenters glue it works best under pressure, i.e., clamped! Super glue might hold it in place but I doubt if it gives the other glue enough pressure to get the best bond.
Out West Woodcarving Blog:
Out West Gallery
Old 01-08-2012, 11:03 AM
That's where quick set epoxy, the 5 minute stuff excells. Bonds like crazy and fills voids with a super durable material. I see there is also a 1 minute epoxy but have yet to try that. Heck it takes me longer than that to mix the durn stuff.
Old 01-08-2012, 04:48 PM
STAR's Avatar
Thanks for the advice Lynn and Al. Looks like epoxy and super glue might be the better option for those fiddly bits.
Pete
super glue finish Robert Cahill Wood Carving Tips and Techniques 11 08-15-2011 12:58 PM
Super glue for cuts Colin-Partridge Wood Carving Tips and Techniques 7 09-22-2010 11:26 PM
A nifty little super glue..... Callynne Wood Carving Tips and Techniques 4 01-06-2010 08:52 AM
Super Glue Guest Wood Carving for Beginners 16 09-11-2004 05:19 PM
