Old 01-31-2010, 11:04 AM
North of 49
Default Re: Thumb Guard -Detail Knife
Larry that is a nice blade and well done. Would it be OK with you if I were to "borrow" your design. Only for personal use.
Old 01-31-2010, 04:53 PM
therenow's Avatar
Hi Larry
I have been using the self adhering tape from Texas Woodcarvers supply and just as you, have found that a few wraps around the thumb holds its shape and form. Works as well as the leather ones that kept falling off.
I ma interested in the knives you made from a recip saw blade. Can you tell me the grinding steps or shaping procedure?
If at first you don't succeed....Call in an air strike... set it on fire..then try again
Old 01-31-2010, 05:06 PM
Dagwood's Avatar
nice looking knife u made there Larry
DWAYNE
Old 01-31-2010, 10:23 PM
Larry Bev's Avatar
BaBo
Send a message via AIM to Larry Bev
To start thanks to all for nice comments.
Dicky after all the help i have received on this site if it would be helpful you or any one else are more than welcome.
I will try. I use wire brush on grinder to remove paint,use fine point marker to draw blade shape, use metal cutting burrs on drill press that i found at yard sale to shape blade i think you can order them from machine shop suppliers they will not burn metal, I use grinder buffer i made from floor buffer it turns slow enough so you can control heat, i also have grinder buffer made from old neck massager it turns extremely slow.
Larry
I'm not getting older just getting closer to my home
Thumb Guard Whittled Thumb General Wood Carving 16 11-15-2009 02:12 PM
Thumb Guard schaf Wood Carving for Beginners 21 08-08-2008 04:54 PM
Thumb guard Shimmy Wood Carving Tips and Techniques 9 12-13-2007 08:15 AM
Ever misplace your thumb guard? Coffeeman Wood Carving Tips and Techniques 7 02-16-2007 08:38 PM
thumb guard Bartster Wood Carving Tips and Techniques 10 06-24-2006 11:04 AM
