Re: Small scale fish carving I'm not sure how small is small after seeing the thread about 'how small can you go'. If it's within reason and not knowing the type of wood, chisels can take you there as would knives. If you have an engraver I am assuming the type that can etch or engrave your name on a piece of steel or something with a vibrating point.That type really won't work well. If it's a high speed micro motor though,spinning small diamond type bits for example,,that can be used as well.Though it tends to fuzz up some woods. You can also use a burner to do some really small and fine detailing of scales and here a painted finish is generally used as the burning might not be attractive to look at.So you have a variety of options,depends on your ability and comfort in using each one,what you have on hand or are willing to purchase. |
