Old 07-03-2011, 09:05 AM
davidinsarasota's Avatar
Default Problem solved with Danish Oil
I'm in the final stages of carving a gargoyle out of Norfolk Island Pine (Araucaria heterophylla). I had a hard time deciding whether to go with a sanded surface finish or a tooled finish, which preserves the channels and ridges made by the gouge. Either would have worked with this piece since there are plenty of interesting contours so that a smooth surface would not have been bland and boring. The creature's back is a fairly large flat area, but this wood, surprisingly, has a lot of random, beautiful patches of black and amber that would add enough interest to allow smooth.
I ultimately decided to leave a tooled surface since the color and grain were strong enough to show through the texture. Also, the tooling helps convey that the piece was hand carved, or maybe I would just rather be carving than sanding.
Anyway, I kept running into random spots in the wood that would not carve cleanly no matter how sharp the tool was or from which direction I approached it with the gouge. As the gouge slipped through its channel, the wood would fold or wrinkle. These wrinkled areas would sand out, but I was not happy with having to leave smooth patches among the tooled areas.
Since oil smooths wrinkles on skin, I decided that because I intended to apply Danish oil and bee's wax as the final finish, why not experiment with applying oil to the wrinkled spots and see if softening/moisturizing effect would allow the gouge to carve cleanly. It worked!
I am doing this on a spot basis at the moment in case I need to use a rotary bit or flap wheel in a particularly tight area; the oiled wood clogs the bits something fierce.
The three pics show the wrinkles before oil, oiled and oiled and carved.
Old 07-03-2011, 11:24 AM
Nomad's Avatar
Default Re: Problem solved with Danish Oil
That's a neat trick Dave. Did you try the 50:50 mix of alcohol/water?
Old 07-03-2011, 01:59 PM
Didn't try it Nom. What's the idea? Raises the grain so you can snip it off?
Old 07-03-2011, 02:37 PM
Nomad's Avatar
It softens the wood so it's easier to carve. It might help those bad spots carve more cleanly. I dunno.
Old 07-04-2011, 07:26 AM
Dan Wegiel's Avatar
One Chip At A Time
Hi Dave,
Since I usually carve found wood that almost always has a bad spot here or there I apply danish oil and let it set for a day or two, IMO it actually hardens those spots(sets up) and make it easier to get good clean cuts.
Dan
Old 07-04-2011, 08:06 AM
Buffalo Bif's Avatar
Buffalo Bif
Send a message via Yahoo to Buffalo Bif
Excellent tip. Thanks.
Brian
BuffaloBif
What one man can do, another can do.
My Blog
Old 07-04-2011, 08:30 AM
carver6's Avatar
I think a 50/50 alcohol/water mix is more to help soften a hard wood or make an end grain piece easier to carve. Don't know about firming up a soft spot but seems to me it would make the problem worse. Guess the best way is to experiment on some scrap pieces if you got 'em.
Garon
Old 07-04-2011, 08:48 AM
Nomad's Avatar
Garon
I see what you are saying. Makes sense. Sounds like a little experimentation is in order.
Old 07-04-2011, 01:30 PM
Good to know about letting it soak for a day. I'll soak the area real good at the end of each session, thanks Dan.
My Computer Problems Finally Solved! Lynn O. Doughty Off Topic 13 10-15-2009 04:42 AM
Dust Collector Problem Solved tucker1931 Power Carving 1 01-11-2009 09:47 AM
All this is junk.... solved jartzh General Wood Carving 12 08-29-2008 02:36 PM
Danish Oil - how to? hruukki Wood Finishing and Painting 4 03-03-2008 07:35 PM
Dry wood problem solved! Mike Carving Wood & Materials 4 08-27-2002 04:36 PM
