I heard of this technique from a carving video on YouTube and that carver's wood definitely looked like butter compared to what I'm using (both basswood). For those of you who use alcohol/water combo what strength of alcohol do you use in the mix? I've seen 30% and 70% rubbing alcohol at my drugstore and was wonder which would work best. |
#12
I use a 90% rubbing alcohol because that is what I had. I tried just water and just the alcohol and the mix is the best. The water made the caring a little easier. The alcohol dried to quickly. When I added the alcohol to the water the knife seemed to slide smoother. My theory is that the water keeps the alcohol from evaporating and the alcohol lubricates the blade. Hope that helps.
__________________ If at first you don't succeed, skydiving may not be for you! Website - D.K.Hummel Company Blog - Carving Country Pictures - Picasa Web Albums Videos - YouTube |
#13
Thanks Dave i have cypress knees i had given up on will try your method. Larry
__________________ I'm not getting older just getting closer to my home |
#14
What about soaking the wood in a bucket of water over night? I'm new here.
#15
That might be counter productive as most carvers try to dry green wood prior to carving to reduce cracking in the finished work.
#16
I try to avoid much water.....could rust your knifes if not cared for....and at the price...something like .88 cents for a quart.....I just use straight rubbing alcohol..........!
| Problem sealing a carving | Dan C | Wood Finishing and Painting | 27 | 03-16-2009 06:45 PM |
| Problem carving where beard meets cheek | Dan C | Caricature Carving | 6 | 03-10-2009 03:45 PM |
| Carving Problem | Yvonne_A | Wood Carving for Beginners | 10 | 06-20-2005 02:02 AM |
| Bass wood problem | Chahlie | General Wood Carving | 23 | 01-12-2005 09:19 PM |
| Dry wood problem solved! | Mike | Carving Wood & Materials | 4 | 08-27-2002 04:36 PM |
