I find that sometimes wood is almost too dry to carve easily, especially in the winter when the humidity is low. It seems to splinter out and dull the tools faster than wet wood. The solution that I found is to mix distilled water and rubbing alcohol in a 50/50 proportion and spray it on the wood with a misting spray bottle. I saturate the area that I'm ready to carve and let it soak in for a few seconds. What apparently happens is the water absorbs into the wood and keeps the alcohol from drying out too soon. Then the alcohol makes the tool glide along more smoothly and cuts down on sharpening. Try it and see if you have the same results. PS: I use distilled water to cut down on mold growing in the bottle. You would think that the alcohol would do this but whatever is in my tap water seems to get nasty after a couple of weeks in the bottle.
__________________ If at first you don't succeed, skydiving may not be for you! Website - D.K.Hummel Company Blog - Carving Country Pictures - Picasa Web Albums Videos - YouTube Last edited by DewragDave; 05-01-2009 at 12:55 AM. |
Hey Dave, Thanks for the tip! I am carving some cypress right now and not only is it dry but if your familiar with cypress it is sort of "stringy" for lack of better word. ou know when you have to go cross grain its really hard to get a good cut. Anyway I am going to try your mix and see if it helps... Tom |
Dave, I always keep a spritz bottle of 50% water/50% rubbing alcohol handy. I never had a problem with just using tap water though.....sort of makes you wonder what you're drinking, huh? We used to have well water but hubby insisted on switching over to city water two years ago, he has high blood pressure and thought it would have less salt in than our conditioned/softened well water.....I didn't but he won out! All I know, is that the cast iron steamer that sets on top of the woodburner now 'grows' a really thick, heavy white crust that you have to scrap off! He says it's calcium deposit....looks like salt to me.....either way, that never happened with our well water!! Anyway, back to the carving part....I think that the alcohol helps keep any mildew from growing on the wood too. I never thought about it helping open the fibers, but that makes sense, it certainly does make a huge difference in making the wood easier to carve, that's for sure! Thanks for mentioning it! Deborah
I had a piece of mahogony that was so dry it gave me problems carving it and I have used and still use the water and alcohol mixture but in this case I used 30 weight motor oil. I brushed it on and let it soak in and then carve until it got to the dry wood again. Worked pretty good this way. I posted a picture of the results. it is 3" thick and 18X24
__________________ RON&PAL View my work@ http:www.westvirginiawoodarts.com www.Blindartistsociety.com |
Thats a sweet sailin ship! Gonna look great on someones wall!!!
| wizzla111 - Sounds plausible, I'm no chemist (LOL) All I know is that water alone will absorb but not make the carving as smooth as the alcohol additive. I'm going to try a side by side test to see which one absorbs better. Ron Davidson - Will it still take finish if you don't carve off all the oil? Also, the ship is cool! Callynne - I wonder if the softened water would leave a salt or calcium deposit in the wood and turn white later when dry? Mudbone - Cypress can be a tough nut to crack if your tools are even a little bit dull. Side cuts are sure to get tear outs in my experience. I've recently been using a dremel on cypress to get a smooth cut, but it's not the same as using hand tools. The mix should help.
__________________ If at first you don't succeed, skydiving may not be for you! Website - D.K.Hummel Company Blog - Carving Country Pictures - Picasa Web Albums Videos - YouTube |
DewragDave it still will take a finish in this case I used Danish oil with a light coat of deft. It really soaked up the oil.
Howdy Ron, Beautiful carving - great detail, that's the beauty of hardwood. Dave, Thanks for the tip, I carve yellow cedar quite a bit and will try adding the water/alc. mix. as well a oil or whatever's handy. Tear out is a real problem going cross grain. Regards, Merv |
I've used alcohol and water mix on hard,dry driftwood and it worked pretty good. Found out on accident that walnut oil on a carving helped too.I had to shave off a mistake on a spoon that I had put multiple coats of walnut oil. Made the carving go real easy. It also kept the dust down on sanding.
__________________ My Gallery- http://www.woodcarvingillustrated.co...on-of-the-dell My etsy store- http://www.etsy.com/shop/Woodforddel...f=pr_shop_more |
Good point Dave, I never thought of that happening, fortunately, it hasn't, at least not that I've noticed, but then, of course, I usually put a couple gallons of paint on my carvings!!! Deborah
| Problem sealing a carving | Dan C | Wood Finishing and Painting | 27 | 03-16-2009 07:45 PM |
| Problem carving where beard meets cheek | Dan C | Caricature Carving | 6 | 03-10-2009 04:45 PM |
| Carving Problem | Yvonne_A | Wood Carving for Beginners | 10 | 06-20-2005 03:02 AM |
| Bass wood problem | Chahlie | General Wood Carving | 23 | 01-12-2005 10:19 PM |
| Dry wood problem solved! | Mike | Carving Wood & Materials | 4 | 08-27-2002 05:36 PM |
