Old 05-13-2007, 07:52 AM
Question Installing and cutting out patterns
Why do some Figure Carvings & Caricature carvings have 2 patterns
and some have 3 & some have 4?
Is there a certain order to cutting the pattern?
If someone could explain or show some step by step pictures
on how to install patterns then cut them out on a bandsaw,
i`d appreciate it.
Thanks for any help
John
Old 05-13-2007, 01:49 PM
Claude's Avatar
Default Re: Installing and cutting out patterns
The current issue of Woodcarving Illustrated has an article about making a Grizzly Bear that shows some of the bandsawing. Often, if a carving is similar on both sides, the pattern only has the front and one side shown. If it's markedly diffent on each side (one arm is out, the other down, for example), both side patterns are shown. Sometimes, when the carving's head is turned, the pattern will show side view(s), front view, and a direct face-on view. Some even show a top view, when it helps define the carving.
My web site
Old 05-14-2007, 07:23 PM
MelNM's Avatar
One reason is thats the way a carver has trained him or herself how to set up patterns for your carvings. Also part the reason for more veiws is so whomever is using the pattern can have an idea on how the carving should look. I have also seen patterns with one view, which is the side view. Thats the way I learned and have also do my own patterns.
This is a good question and I'm sure you'll get a lot of good answers, these are just my reasons why.
Mel
He who laughs last probably does not get the joke.
My Gallery
Old 05-16-2007, 02:00 AM
Thomp's Avatar
Forum Mentor
Try this link, i wrote something on making but the "pattern installing is covered." as you call it...
click below->
Pattern Createing ?
Thanks Thomas,
Email:
thomp51la@gmail.com
Cutting out wood Kenny_S Off Topic 2 01-15-2006 02:28 PM
im' under cutting too deep? Thomp Caricature Carving 6 01-10-2005 01:18 PM
Cutting trunks Saturno10 Woodcarving Tools, Technology & Sharpening 8 05-18-2003 03:47 PM
cutting against the grain newtools General Wood Carving 2 11-22-2002 08:10 PM
Cutting down an edge ah_chip Relief and Chip Carving 10 09-09-2002 01:18 PM
