Old 04-24-2008, 11:10 AM
xsailer's Avatar
Default Filler for too deep saw cut
After spending two days roughing out and fitting a carving I've discovered when I finish carving the piece a 1/32 to 1/16th deep saw cut about 3/8" long may be visible. It's on the underneath side of a bird carving and the finally effort will be painted. I'm thinking same wood sawdust mixed with 'good ole' elmers glue as a repair.
The carving is for a customer and I want to give the very best but I sure don't want to start over.
Any thoughts or suggetions?
Old 04-24-2008, 12:10 PM
Default Re: Filler for too deep saw cut
Bob, there is a product named Quikwood that is great filler. Only thing is that it dries a light gray color instead of a natural wood color and a stain wash will show the repair. If you are painting to get a full color it will work fine. Another fix I've used before is to carve out an area that you can repair with another carved matching wood patch. Take your time and if possible angle the sides so the patch is unnoticeable after drying and trimming down to match the original.
Norb
You might try carving a slice of scrap from which the piece was carved and glue it in the saw cut. The sawdust and glue will fill the cut but it may not take a finish. You could also get a product called QUIKWOOD which is an epoxy putty and can be stained or painted. You should be able to find it at Home Depot.
Old 04-24-2008, 12:22 PM
That Quickwood will work just fine, as will Elmers wood filler, Plastic Wood or any number of commercial fillers. I've used them all with good results. Some are easier to work than others but there really isn't a whole lot of difference in workability.
Old 04-24-2008, 03:31 PM
Ph.C, C.E.P., G.B.A., WOF
I use Tuf-Carve as it sets quickly, cures hard and is a similar color of basswood. Here's the link:
FMSC - TUF-Carv Polyester Repair Paste
Old 04-24-2008, 04:36 PM
TreeWizard's Avatar
If you are going to paint the piece I'd try auto bondo. It's held up well on the old wrecks I drive.
Old 04-24-2008, 04:57 PM
xsailer's Avatar
Thanks all for your input. I thought of Bondo but never tried it on wood. Don't know why it wouldn't work though.
Lynn, do you know if the Tuf-Carv is available in stores? Wonder how it compares to
Quickwood.
Old 04-24-2008, 05:40 PM
Having never used the Quickwood I couldnt say. The TufCarv is sold by Larry Yudis' Woodcarvers Store. Comes in a quart can with a little tube of hardner.
Old 04-24-2008, 10:29 PM
Blake Lunsford's Avatar
Surely you never have to use the stuff though, do you Lynn?? I thought old faithful never let you down.
Blake
Blake Lunsford
www.picturetrail.com/blakelunsford
Old 04-24-2008, 11:04 PM
Sometimes even Old Faithful gets a little agressive.
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f60/filler-too-deep-saw-cut-17147/
Woodcarving Illustrated Message Board This thread Refback 04-24-2008 11:24 PM
What would be a good way to dye maple a deep deep deeeeep indigo color? nameless Wood Finishing and Painting 24 03-09-2008 07:12 PM
How deep is it over here? ElWoodTroll Off Topic 14 03-23-2006 05:43 PM
sanding deep v-cuts Blake Lunsford Wood Carving for Beginners 8 11-06-2005 12:36 PM
Deep and Shallow Relief Paul_Guraedy Relief and Chip Carving 4 04-13-2005 09:52 AM
im' under cutting too deep? Thomp Caricature Carving 6 01-10-2005 02:18 PM
