Old 07-21-2009, 09:35 PM
North of 49
Default Re: how do you make a knife out of a hacksaw blade?
Thanks Thomp
Old 07-21-2009, 09:53 PM
Nomad's Avatar
When you cut metal like that, you might consider using Uniweld Cool Blue heat sink paste. Less likely to overheat the blade when you are cutting.
Old 07-21-2009, 09:57 PM
Nomad's Avatar
I just checked my old hacksaw blade knife and the steel is thinner than I remembered it. You could get a lot of carving blades out of one power hacksaw blade.
Old 07-21-2009, 10:11 PM
Thomp's Avatar
Forum Mentor
Your Welcome Dicky,
yep, them little red abrasive disks that come with dremel kits are dangerous they break to easy and become shrapnel looking for an eyeball.
i think their for working with marshmallows or something.
but occasionally they put in one fiber disk in a package, its a little thicker but it gets the job done,
i found my stockpile at harbor freight... bout 3 bucks for 3 of them with an arbor..
Their made of abrasive/fiberglass material like a weld cutting side grinder blade,
to keep heat at a minimum i cut the small amount of metal on a flooded wet sponge in a big jar lid. yep its tough to keep from getting sprayed... but you dont loose steel,
Thanks Thomas,
Email:
thomp51la@gmail.com
Old 07-22-2009, 07:47 AM
North of 49
Thomp, were sorta goin' down the same road re:cooling. I use a margarine tub full of water with a rag in it and bring the tub to the steel and touch the work with the wet rag every couple of passes. I also use the discs that come in a kit with the arbor.
Old 07-22-2009, 10:56 AM
I cut an extremely hard piece of steel with my abrasive cut off saw....but I just touch the wheel to the metal, then cool with water and repeat until cut, takes a long time, but I haven't hurt the temper yet.
Old 07-22-2009, 11:31 AM
When I'm making a straight razor knife, I take the slow way and continually dunk the blade in water. On other steels, nails, hacksaw blades, etc., I usually heat them to soften the metal, grind them, then re-harden and re-temper. I find it easier to shape and work the softened steel.
I'm not good enough to try to do that to the razor knife though.
http://stickcarving.webs.com/
My Gallery photos.
Old 07-22-2009, 06:47 PM
North of 49
I just finished sharpening the upswept blade I made from an old power hacksaw blade and I can't believe the edge on it. I have had good success making mini turning tools and knife blades with concrete nails in the past. This hacksaw blade takes an edge as good or better than Warren or Pfeil blades do and they take a "scary" one. Now to find a maple burl for a handle.
Old 07-23-2009, 11:00 AM
redhand rik's Avatar
cooling your cutting
i have an old iv bag from when i went to the hospital. i fill it with water and hang it over a 5 gal bucket. there is a "flow adjustment wheel" that will adjust from no flow to full flow and everything in between. the tube is held by a piece of wire wrapped around it so it can be positioned. i use this for carving stone and cutting metal.
trust me lady, i just LOOK like the guy your mother warned you about!
New Knife. blade will not keep an edge. aulddiy Woodcarving Tools, Technology & Sharpening 12 12-30-2008 01:48 AM
where to buy a blank blade to make a carving knive? carverswoodshop Woodcarving Tools, Technology & Sharpening 10 01-19-2008 06:06 AM
Different knife blade shapes - what are they for? chuckt Wood Carving for Beginners 18 07-15-2007 04:29 PM
How long should my knife blade be? Whittlinwit Woodcarving Tools, Technology & Sharpening 5 02-08-2004 06:47 PM
Knife Blade Shapes Guest Woodcarving Tools, Technology & Sharpening 8 12-14-2002 06:35 PM
