Old 01-26-2007, 10:02 AM
Tom H's Avatar
Default Cleaning up fuzzy/messy carvings
This is a question for all you wood carvers and especially those who are "tinkers" (Thomp you listenin?). I am a lazy whittler. My carvings, or should I call them whittlins? Have very messy cuts. Mostly I can help the situation with a good scrubbing with a denture brush and "Mean Green". But, after looking at some of the carvings of our super carvers on this site, I see carvings that look as smooth as silk. Now my question - could a wood carving be "cleaned up" by the use of a pressure regulated sand blaster; using fine silica sand? I would try it, but I don't have a sand blaster. I was thinkin bout a airbrush type apparatus.....Maybe a dumb idea! Tom H
http://www.flickr.com/tomh2
Old 01-26-2007, 10:07 AM
Colin_Partridge's Avatar
Default Re: Cleaning up fuzzy/messy carvings
Not so dumb Tom it is a very logical thing to do. Now I have done it with great results on my large carvings from time to time. I take them to the local sand blaster and he dusts them off with the big hand held machines. When I say dust he takes one swipe takes about 5 seconds for a four foot carving and the results are amazing. I have had him try some with more intensity but all it does is remove some of the detail and raises the grain.
As for smaller stuff I have never tried it.
Colin
Old 01-26-2007, 11:06 AM
Tom,
Fuzzies are the result of not making clean cuts. One of the keys to carving is avoid making 2 or 3 cuts, when it could be done with only 1. Making the shape with one cut will eliminate fuzzies. Try making more aggresive cuts to avoid them.
Thanks,
Dan
Old 01-26-2007, 11:55 AM
Mitchell's Avatar
^ Bingo.
The best way to clean the fuzzies is not to make them. Be sure to use "good" stop cuts.
You can use a burner to clean up cuts also.
Old 01-26-2007, 12:06 PM
Tom H's Avatar
Oh! I know how to prevent the fuzzies. But I am a "nibbler" with the knife, and besides that I am a type A person who thinks he's always in a hurry. And just maybe. I am lookin for an easy way out....Tom H
Old 01-26-2007, 01:27 PM
The best advice is to just take the time to learn to do it the correct way then you will solve two problems...
You will solve the rough cut or fuzzy problem.
You will become a better carver.
Old 01-26-2007, 02:01 PM
Mitchell's Avatar
Being a "nibbler" is the worst.....that's one of my problems too. However, if I am carving something that I know that I want to be "good", then I don't nibble.
I like to "doodle" - pick up a piece of wood and play with it until I discover what I really want to carve. Sometimes I never figure it out. - sorry, sidetracked....
I don't think that there is an "easy" way to clean up fuzzies in creavices. The carver that tries go go back into these spots usually only makes matters worse. Brushing and/or burning is an option that I will use on occasion.
If it's really bad, the carving goes into a box and I start over.
PS: There have been some other discussions on this topic. Here's one that's sort of related:
http://woodcarvingillustrated.com/fo...hlight=fuzzies
Old 01-26-2007, 03:02 PM
wood-whittler's Avatar
tom,
another key to clean cuts is to make sure your knife is sharp, hone it before makeing delicate cuts and like it has been said take your time.
bart
Old 01-26-2007, 03:11 PM
mycarver
There is a style of sign "carving " I'm sure most of you have seen where sandblasting is used to make the sign. Areas are masked and the rest is blasted, removing at times quite a bit of wood leaving a deeply textured surface. I would be afraid, till you figured out the pressure/grit,etc, and the finish it might leave on small carvings would destroy any detail or carved finish you might have,,even if you're a nibbler,,just nibble clean cuts,till you work your way to where you want to be.There is nothing wrong with taking multiple cuts,you have a greater margin for error,One major cut done wrong is harder to fix than taking the time with several smaller ones and sneaking up on it.
website at
www.woodworkingstudio.net
e-mail to
mycarver@rcn.com
Old 01-26-2007, 03:22 PM
mdallensr's Avatar
There are times when fuzzies are unavoidable. You may have to carve cross-grain on a really soft spot, or carve up-hill into the grain to undercut, and you end up with a scruffy looking cut, even with sharp tools. I fix some of those on curved surfaces with a curved knife, which allows me to slice small cuts and finish a rough area. For de-fuzzing stop cuts, a Dremel with a bristle wheel works wonders, as does the Scotch-brite home-made wheel. The new, 3-M discs are great for cleaning those areas too. Recently I carved some too-soft butternut and cypress that fuzzed when I looked at it. I used some pointed, flame shaped Dremel stones on those to salvage them and they looked fine. Mike
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f60/cleaning-up-fuzzy-messy-carvings-11320/
Wood Carving Tips and Techniques [Archive] - Woodcarving Illustrated Message Board This thread Refback 03-07-2008 11:54 PM
Big Fuzzy Sleepers Mark Gargac New Projects and Works in Progress (WIP) 13 11-29-2005 09:29 PM
detail cleaning Alice in Wonderland General Wood Carving 12 12-23-2004 11:18 PM
Cleaning up a carving ken Wood Carving for Beginners 4 12-11-2003 09:47 AM
Cleaning Question SantaCarvinLady Wood Finishing and Painting 8 10-22-2002 07:16 PM
Cleaning carvings Gravel_Girl Wood Finishing and Painting 5 08-05-2002 10:39 PM
Santa Carving Contest
