I bet this has been answered before, but I'm having trouble finding it, so I'll just ask. I would like some information on strop cleaning. My strop has a bit of used compound build up on it and I would like to know if it is neccessary to clean it off or just add more. Any tips on how to clean it would also be helpful. Thanks in advance.
I use the green stuff (chromium oxide?) on my strop, and haven't cleaned it in over 5 years since I made it. Still seems to do the job just as it did with clean new compound on it... I never scrape it, just add more every now and then. In the "little known and generally useless" category: most stropping compounds are metal oxides. Aluminum oxide (think black wet/dry sandpaper) is the third hardest (after diamond and silicon carbide) substance know. This very small particles (sub-micron) actually scrape bits of the steel off your knife when you hone it (this is why it gets mirror-like). These scraped bits are very very small and mix with the wax-based oxide on the strop. [Opinion:] Eventually, if you live long enough, you might get enough steel bits mixed in with the oxide bits that it will no longer work, but I suspect none of those living on the planet now will be alive when that happens... You can strop you knife blade using plain old cardboard, such as the back of a pad of tablet paper. It will take longer than the same piece of cardboard with some stropping compound on it, but it will work. For my detail knife, which has a very thin and flexible blade, I use a piece of basswood with some compound rubbed on it. Works like a champ! Here are four previous threads with this subject: Cleaning slip strop ? Do I clean the Strop? Cleaning strop clean strops Claude Last edited by Claude; 11-20-2009 at 05:45 PM. |
Most people seem to just leave it. If it does get in your way just scrape it off with the back edge of your knife or the side of a gouge. I just leave it until it falls off on its own or forms a ridge along the strop & then I scrape it off with the back of a knife. I suppose you could also use one of these: Jantz Supply - Your source for knifemaking! RussL. |
I also just add more compound to the old compound, I don't scrape anything. Dave |
I could be imagining this but I think mine is getting better with age (about five years now) I have never cleaned or scraped it. I just continue to add more compound. Lundy
__________________ www.lundycupp.com |
add more compound. I don't know if it is "right", but it works for me!
OK, DanKed, so glad you brought this question and the seasoned fella's answered. You have put my mind at rest..yeah I know really??? lol Anyway I have just let the compound (yellow) build up. So sounds like it's not a big deal and the strop gets better with age. Kind of like me....tee hee. Kathy
__________________ KATHYMy WCI Carver Gallery Images http://www.woodcarvingillustrated.co...3480&protype=1 The Flute Portal http://www.fluteportal.com Back Roads and Tall Trees |
John Dunkle told me that if you're using yellowstone compound & your strop isn't black, you don't have enough on it.Said when it turns black is when it's working right. Like Claude said, it's all some kind of metal oxide so, I would think that all of it would work best after it has gotten good & black.
| Bur cleaning | John_C | Power Carving | 16 | 08-28-2010 12:28 AM |
| Cleaning slip strop ? | wizzla111 | Woodcarving Tools, Technology & Sharpening | 39 | 06-25-2009 02:32 PM |
| chip cleaning up. | aulddiy | Relief and Chip Carving | 6 | 03-29-2009 10:39 AM |
| Cleaning strop | Gulf Coast Handyman | Woodcarving Tools, Technology & Sharpening | 13 | 11-28-2007 04:12 PM |
| Time for some cleaning | mwilleson | General Wood Carving | 7 | 02-06-2006 11:08 AM |
