Dale Green Woodcarving
Old 12-16-2012, 05:08 PM
mdallensr's Avatar
Default Carving bench hooks
Another message board member asked me to post some photos of the bench hook and tool holder I use for my sit-down carving. I also made a flat version that travels better. The angled bench hook is 18" wide by 21" deep, with mostly 1/2'" diameter holes, but they're sized to match the metal ferrule on the gouges (some are 5/8" and a few are 3/4"). The holes are 1 1/2" on center and the rows are 1 1/2" apart and staggered. The foam covering is carpet pad that I glue on with contact cement. Non-skid drawer liner works well to but isn't as durable as the carpet pad. I glue the drawer liner on the bottom of the bench hook to keep it from sliding and scratching the table top.
I make the bench hooks from scrap counter-top material from the local DIY's. The bottom support piece is cut from the counter-top and attached with wood screws before the carpet pad is glued on the top. Plywood works fine too, but the "hook" is already on the counter-top, so it saves a step. Mike
Old 12-16-2012, 05:24 PM
Default Re: Carving bench hooks
What a great idea, Mike! I always enjoy seeing how others make use of materials they have lying around. Thanks for sharing.
Cheers,
Tony
Old 12-16-2012, 05:36 PM
Rodster's Avatar
Nice bench hooks. You've done a great job. I suspect they work the best with relief carvings. I made a small one some time ago, but I haven't used it often, since I tend to carve little caricatures that I hold in my hand. Still the carving board (as I call it) sits astride my tool tote to hold gouges and v-tools while I'm working outside or at a table. I've grown rather fond of it. Here is a picture of the carving board atop my tool tote, with five little people.
I've started painting the little folk since I took the picture.
Budget ornament hooks Soggy Wood Carving Tips and Techniques 8 01-17-2010 03:55 PM
Using Fish Hooks for Ornament Hangers Ed Redwine Wood Carving Tips and Techniques 13 07-05-2008 06:07 PM
Bench Carving Juhani General Wood Carving 3 06-17-2008 12:42 PM
Ornament Hooks mbevington Wood Carving Tips and Techniques 13 07-05-2006 09:09 AM
carving bench tip Hi_Ho_Sliver Woodcarving Tools, Technology & Sharpening 8 06-09-2006 02:09 PM
