Old 03-15-2008, 11:52 AM
Default Re: bandsaw scroll cutting problem
Yes !! Super idea !!
Many thanks, CDC
Old 03-15-2008, 11:56 AM
Originally Posted by Ashbys
I moved the thread , to here, as the area it was in was the wrong place. I am trying to under stand excatly what your asking .
You have cut a 6 Dia circle . say 1 inch thick .
Now your trying to make it 1/2 inch thich by cutting the two sides ?
Ash
Not quite; it is a 6" cylinder the ends of which I needed to cut off since the ends had some decorative carvings. Should have cut the ends before completely finishing the cylinder before doing the carvings....thanks,
CDC
Old 03-15-2008, 11:59 AM
Ron,
Thats what I was thinking, if it is well there are ways to do it. But the simplest answer is scrap it cut it to depth and then cut the 6 inch circle. If that isn't an option, the get a V Clamp . The safest way , of course a V clamp for 6" can be a bit costly. Another way , flat clamp the sides in a drill vise , mount the vise on a right angle , Cut down to the vise cross cut to the cut and remove the first cut , rotate , reclamp make another cut.
Then we can get fancy . From there. Personally , I would bench vise clamp , get my hand saw .......
The speed the blade is moving you need a solid clamping point, with out being clamped it is an accident waiting to happen.
Dad always told me accidents are caused .. they don't just happen.
Ash
Great advice !! Finally hot glued the cylinder into the blank, then cut the ends,,,,,
THANKS !
CDC
Originally Posted by Hi_Ho_Sliver
If you "tack" it...you will cut thru with your blade.....! Maybe some hot glue?
Absolutely !! WORKED !!
Thanks, CDC
Old 03-15-2008, 12:00 PM
Originally Posted by whittlewomen
Hi,
Can you tack the six inch piece to another board before you cut? I do this often when doing small projects.
Sharon
Did so - with hot glue !
Thanks, CDC
Old 03-15-2008, 12:01 PM
YUP !! Worked !!
Thanks, CDC
Old 03-15-2008, 12:02 PM
Originally Posted by mark yundt
Why not just clamp the circular piece to a square block and then take it to the bandsaw. You now have your stability,,it won't spin,,,and you can cut it any way you like. I've done this many times myself.
Then again,,maybe I'm not understanding the actual problem accurately.
Super advice ! Thanks, CDC
Old 03-15-2008, 12:04 PM
Originally Posted by Ron Davidson
Ash sounds like he is trying to cut it while it is standing on edge or round and as soon as the blade hits is it spins. At least that is what it sounds like to me.
Exactly the problem !
Old 03-15-2008, 12:06 PM
Ash
Actually is a 6" dia cylinder that I wanted to cut 1/2" inch off both ends that had some decorative carvings on them. Should have cut the ends first while still attached to the original block the done the carvings.Many thanks, CDC
Cutting a Pattern on a Bandsaw jstive Wood Carving for Beginners 10 06-26-2007 01:16 PM
cutting MDF-will scroll saw work? mchurchill Wood Carving for Beginners 2 08-25-2005 09:06 AM
Looking for the Scroll Saw Forums admin Message Board FAQ, Suggestions and Feedback 0 12-29-2004 01:28 PM
Violin Scroll revjim General Wood Carving 1 09-17-2004 08:31 PM
Scroll saw or Band saw????????????? nwar Woodcarving Tools, Technology & Sharpening 11 08-04-2003 03:53 PM
Santa Carving Contest
