| (My first post): Sad I am fabricating a round bandsaw box. I have a Powermatic 14" bandsaw and need to cut a 1/4" face from face and back of a 6" circular piece of hard wood. Every time I try to do this, the piece spins out of control and is thrown off the table. Any suggestions ? |
I moved the thread , to here, as the area it was in was the wrong place. I am trying to under stand excatly what your asking . You have cut a 6 Dia circle . say 1 inch thick . Now your trying to make it 1/2 inch thich by cutting the two sides ? Ash |
Ash sounds like he is trying to cut it while it is standing on edge or round and as soon as the blade hits is it spins. At least that is what it sounds like to me.
__________________ RON&PAL View my work@ http:www.westvirginiawoodarts.com www.Blindartistsociety.com |
Ron, Thats what I was thinking, if it is well there are ways to do it. But the simplest answer is scrap it cut it to depth and then cut the 6 inch circle. If that isn't an option, the get a V Clamp . The safest way , of course a V clamp for 6" can be a bit costly. Another way , flat clamp the sides in a drill vise , mount the vise on a right angle , Cut down to the vise cross cut to the cut and remove the first cut , rotate , reclamp make another cut. Then we can get fancy . From there. Personally , I would bench vise clamp , get my hand saw ....... The speed the blade is moving you need a solid clamping point, with out being clamped it is an accident waiting to happen. Dad always told me accidents are caused .. they don't just happen. Ash |
Many thanks !! Maakes perfect sense !! I also discovered that I hadn't changed to a resaw blalde CDC |
Why not just clamp the circular piece to a square block and then take it to the bandsaw. You now have your stability,,it won't spin,,,and you can cut it any way you like. I've done this many times myself. Then again,,maybe I'm not understanding the actual problem accurately. |
Mark your right. The whole point is clamping to lock the piece solid. It is our safety standard to Vee lock rounds for any operation so I go right there . 30 years of habit . Ash |
Hi, Can you tack the six inch piece to another board before you cut? I do this often when doing small projects. Sharon |
If you "tack" it...you will cut thru with your blade.....! Maybe some hot glue?
WOW !! Gteat idea, and it worked !!! Many thanks, CDC |
| Cutting a Pattern on a Bandsaw | jstive | Wood Carving for Beginners | 10 | 06-26-2007 01:16 PM |
| cutting MDF-will scroll saw work? | mchurchill | Wood Carving for Beginners | 2 | 08-25-2005 09:06 AM |
| Looking for the Scroll Saw Forums | admin | Message Board FAQ, Suggestions and Feedback | 0 | 12-29-2004 01:28 PM |
| Violin Scroll | revjim | General Wood Carving | 1 | 09-17-2004 08:31 PM |
| Scroll saw or Band saw????????????? | nwar | Woodcarving Tools, Technology & Sharpening | 11 | 08-04-2003 03:53 PM |
