| Found the Fox?
| Off Topic |
11-18-2007, 10:31 AM
|  | WCI Author | | Join Date: Apr 2005 Location: East Coast, US
| | Senior Moment - Help! I am having a senior moment ... I want a dowel jig that resizes the diameter of a dowel rod. It has pre-drilled sharpened holes where you force the dowel through each hole, slowly working towards a smaller diameter, until the dowel has the new desired dimension. Each new smaller hole shaves off just a touch of wood, reducing the size of the dowel.
I have searched under dowel, dowel jig, and spoke shave but all I come up with is either dowel centering pins or a centering jig for the drill....
Help! Name that jig. Please!!!!
Susan
(I know when someone tells me I am going to feel so very stupid for not thinking of it myself ...  |
11-18-2007, 11:07 AM
| | Member | | Join Date: Jan 2005
| | Re: Senior Moment - Help! I believe Lie Neilson tool Works has dowel plates.
Lie Neilson tool works.com
I think this is the web site, at least it will get you close enought to find it.
Ed |
11-18-2007, 11:24 AM
|  | Moderator | | Join Date: Dec 2001 Location: East-central Missouri
| | Re: Senior Moment - Help! Yes - dryheat is correct. Lie-Nielsen is also carried by Woodcraft. www.woodcraft.com -- LIE-NIELSEN DOWEL PLATE -- Item # 823413 -- $44.99
I "know" I've seen a different, cheaper one in a different catalog but, of course, I can't remember or find it. |
11-18-2007, 01:56 PM
| | Butter Fingers | | Join Date: Jun 2005 Location: W. New York
| | Re: Senior Moment - Help! I have L-N's dowel plate. It is not easy to use.
There is quite a bit of wood that has to be removed between dowel sizes and it is hard to keep the dowel centered in the hole to get a perfect circle.
The grain in the dowel has to be perfectly straight and it requires a lot of force to pull the dowel through the hole.
It does excell in making small length dowels to use as plugs using a mallet to drive the wood through the hole.
I would suggest making your own out of a piece of metal flat stock. |
11-18-2007, 11:21 PM
| | talk about "senior moments" I kept looking for the dowel jig I just KNEW was in one of my catalogs ..... I found it. |
11-19-2007, 10:27 AM
| | Re: Senior Moment - Help! Thank you everyone!!!!
Nancy, which catalog? I am resizing bamboo and hardwood knitting needles and that one looks perfect with it's slow progression through the sizes.
Thanks again, everyone.
Susan |
11-19-2007, 10:33 AM
|  | Teddy bear carver | | Join Date: Nov 2004 Location: Edison, NJ
| | Re: Senior Moment - Help! Hi Susan
I figured I'd answer your question to help you speed things up a bit. http://www.micromark.com/catalogpdf/020-029.pdf
PDF file Page 9, catalog page 27.
Bob L |
11-19-2007, 10:40 AM
| | Re: Senior Moment - Help! Oh, Susan I thought that was a big mistake on small dowels because it starts on 1/16" dowels.
It's in Micro-Mark -- www.micromark.com 800-225-1066
340 Snyder Avenue Ave., Berkeley Heights, NJ 07922-1595
Micro-Mark sells the most wonderful stuff -- it's so much fun -- but the prices aren't.
When I need a tiny dowel I ~blush~blush~ use a tooth pick soaked in thin super glue for strength. But they are NOT made from straight grain or strong wood. |
11-19-2007, 10:41 AM
| | Re: Senior Moment - Help! Quote: |
Originally Posted by Just Carving |
That site looks to me to have Bob Squarebriggs name all over it! lol |
11-19-2007, 10:26 PM
|  | the WOOD BEE CARVER | | Join Date: May 2007 Location: WILMINGTON, OHIO
| | Re: Senior Moment - Help! What is a "Senior Moment?" I used to know what it is, but I keep forgetting. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -4. The time now is 09:02 PM. | |
