Off Topic
Old 12-29-2008, 12:44 PM
Terry Vance's Avatar
"Old" Guy
Default Band Saw Problem - Help!
I have an old Sears table top 3 wheel band saw(photo 1), which was originally made by Black & Decker. I used it for all my small stuff. It started making a wierd noise the other day and I noticed that the lower blade guide and bearing bracket was broken(photo 2).
The $5.99 part on Sears' website shows as in stock, however, is no longer available or in stock. I am hoping that someone here on the site might know of someone with this machine that is scrapping it out and can put me on the trail of a replacement part.
I have visited E-Bay with no luck and I am not aware of another place where I might look.
Any help would be greatly appreciated.
Happy New Year & Keep carvin'
Keep carvin'
God bless you,
John 3:17
http://www.picturetrail.com/terryvance
my WCI gallery
Old 12-29-2008, 12:51 PM
Hugh-P's Avatar
Default Re: Band Saw Problem - Help!
Terry , you might try liquid metal weld, then put plate on the back of it, Make a plate and drill holes and use small stove bolts to hold it together. Just a thought, but it might keep you going until you can find a replacement part.
MY WEB SITE:
http://www.FeathersInWood.com
http://www.Bird-Carvings.com
MY WCI GALLERY
Old 12-29-2008, 12:58 PM
JIM QUILICI's Avatar
senior WCI reader
Also you might try a wielding shop ....they can wield almost anything
Jim
to see some of my carvings...click the link below:
http://www.woodcarvingillustrated.co...ry.php?cat=541
If you put the federal government in charge of the Sahara Desert , in five years there'd be a shortage of sand.
Old 12-29-2008, 04:57 PM
Al_Hillis's Avatar
I too would take it to a welder , almost any machine shop should be able to fix it
http://picasaweb.google.com/al.hillis/WOODCARVINGSMINE
Its better to take two steps forward and one step back then never having danced at all
Old 12-29-2008, 05:02 PM
Actually, I would advise having it brazed...its strong and will hold that for years to come ! In addition, brazing will not require the heat welding does that could distort the casting.....imho
Old 12-29-2008, 06:29 PM
"Old" Guy
Thanks everyone for your thoughts on this matter.
I have both capabilities here at home, just thought I'd put it out there and see what happened. Today I made a very temporary lower guide from 3/4" plywood and at the moment that is working well. I just need to practice with the welder and when I get confident go for it.
Thanks again & Keep carvin'
Keep carvin'
God bless you,
John 3:17
my WCI gallery
Old 12-29-2008, 06:50 PM
Goody's Avatar
If its cast aluminum you will need to tig weld it and you will need a high frequency converter. If its an iron casting brazing it as Hi Ho Said would be the way to go. Welding cast is tricky without special rod and a way to heat the metal before welding and then cooling it in an oven slowly. It may look good but there will be a lot of crystalization and inclusion in the weld as well as the metal will become very brittle near the weld.
Goody
Formerly Decoycarve
http://www.goodysfolkart.com
Old 12-29-2008, 06:57 PM
Hadn't thought about it being aluminum but that is entirely possible! I have some rod in the shop that is very low heat and is for welding/brazing aluminum...if it comes to that let me know and I will try to find the name of the stuff....
Old 12-29-2008, 07:27 PM
Kenny_S's Avatar
Senior Moment
That is ok Terry, I am a Gorilla Welder, Big and ugly. Well the weldings also.LOL
God Bless
Kenny
Old 12-29-2008, 08:24 PM
Hugh-P's Avatar
I still say try the Liquid Steel, that stuff will hold. I've used it with very good results. With a plate bolted to the back of it, it would be OK, until he could find a new part. It would take a professional to weld white metal, with the chance it would be distorted, and then he would have nothing to use.
MY WEB SITE:
MY WCI GALLERY
band saw? James A Woodcarving Tools, Technology & Sharpening 8 09-26-2008 01:47 AM
Help with Band Saw jillsy Woodcarving Tools, Technology & Sharpening 19 12-24-2006 06:35 AM
Dog band whittlewomen New Projects and Works in Progress (WIP) 17 11-10-2006 01:58 PM
Band Saw Which One? Mottles Woodcarving Tools, Technology & Sharpening 82 10-13-2006 05:27 PM
band saw dust problem big_al General Wood Carving 2 07-23-2004 09:30 PM
