Is there a great deal of difference between the Colwood Cub and the Detailer? I'm not a pyrographer but will be getting one of them to do burning on my carvings. Or would I be better off with a different type? I already have a Dremel versatip burner but it isn't adequate. |
I'm not a pyrographer either but sometimes use my Detailer to outline my carvings or to add hair or detail. I'd recommend spending a few extra bucks and going with the Detailer just in case you do decide to expand your work at a later date. One feature that I like about the Detailer over the Cub is that it has a seperate on/off switch so that you can leave your heat setting where it is, take a break, and then get back to work with out fiddlin' around just by hitting the on/off switch.
Do some research..........check out different models colwood optima razertip burnmaster google them spend some time checking out the pro,s and cons to suit your needs then buy the best you can afford........hope that helps Kind Regards Mike The Netherlands
__________________ Sometimes its better to listen - than to talk http://darksidewoodburning.weebly.com |
| Hottest wood burner | JRF | Wood Carving for Beginners | 3 | 11-09-2009 07:54 AM |
| Newbie with burner question | kamac56 | Pyrography and Woodburning | 4 | 07-25-2009 10:02 PM |
| Why use a Wood burner | K. Ellenburg | Wood Carving for Beginners | 6 | 03-19-2008 08:03 AM |
| Wood Burner | jocalm | Woodcarving Tools, Technology & Sharpening | 2 | 02-06-2005 09:20 AM |
| Wood Burner | big_wayne_p | General Wood Carving | 15 | 01-07-2004 01:53 PM |
