Old 09-10-2007, 03:01 AM
WOODIE13's Avatar
Default Photographing Work
Trial and error has taught me a lot. Tips from friends and lessons learned.
For small stuff, most cameras have a macro setting or a flower setting. This allows the camera to focus at a closer distance so you dont get a blurry shot and is in perfect focus
Fill flash. there is a lightning bolt shaped icon on most cameras. it will go from auto , front curtain, rear curtain, off, and fill flash. Fill flash forces the flash to come on so it lights up the subject. Most of the time you will want to use this. If it is too much flash, hold a piece of paper over the flash and it will "soften" it a little.
If not using flash, a desk lamp or even a flashlight will help to illuminate the subject. Also, you can take the pic outside for the natural light to avoid the flash.
For paintings, drawings and burnings remember to not take them "straight on" with the flash. You need to take them at an angle so the flash ricochets off to one side .
A small tripod will do wonders for your pictures. get one that you can fit on the table or desk. They are real cheap at wally world. Use the self timer on your camera (most time the button looks like a clock or timer) this will prevent camera shake.
A dark piece of cloth or solid back ground will make your artwork really stand out. Hang it over a book or a chair back and frame your shot in front of it.
Old 09-10-2007, 09:42 AM
Pyrographer's Avatar
Default Re: Photographing Work
Wow, some great pointers Woodie. It was also suggested to me by a professional photographer that doing it outside when the sun is not out will work best and help avoid shadows.
Personally I also found that if you take your photo before you apply the final finish it helps avoid the glare, especially if you use a finish with some gloss in it. I now use a satin finish which also helps with that.
Nedra
LinkBack to this Thread: http://www.woodcarvingillustrated.com/forum/f58/photographing-work-14039/
Pyrography and Woodburning [Archive] - Page 4 - Woodcarving Illustrated Message Board This thread Refback 11-17-2007 11:51 AM
Woodcarving Illustrated Message Board This thread Refback 09-10-2007 02:36 PM
little more work needs to be done Kenny_S New Projects and Works in Progress (WIP) 27 05-09-2007 06:53 PM
First work Francesco Wood Carving for Beginners 10 11-27-2006 02:24 PM
Photographing carvings? Pete Rieger Off Topic 8 01-09-2006 07:43 AM
A bad day at work! decoycarve General Wood Carving 10 06-10-2005 08:08 AM
Photographing your work. Captain_Bandaid General Wood Carving 5 06-28-2003 01:41 PM
