This is my First attempt at using Water Colours on a Burning Mighty Little Oak taken fron Susan,s Book Wood Spirits and Greenmen Water Colours used on this project; Van Goch.......................Yellow Light Van Goch........................Chinese White Coleman.........................Sap Green and Venus Acrylic.............Burnt Sienna. Look forward to your comments /Critic/Suggestion/Advice Kind Regards Mike The Netherlands
__________________ Sometimes its better to listen - than to talk http://darksidewoodburning.weebly.com |
Hi Mike, It looks like you are well on your way working with water colors. If I might suggest that you try your hand at not burning in the outline on your pictures. Transfer patterns with graphite as always but shade along those lines. Susan covered that some in the tutorial she just did. You'll be amazed at the depth you can create that way. Susan has some fantastic greenman creations, don't be afraid to elaborate on them and add your own touches. It's a great way to ease into creating your own without causing any stress if you're doing it right or not. |
Thats certainly sound advise and will certainly try that out........ Just normal Transfer then shade or work in... instead of burning the outline of the Pattern!! Is that correct...........!! Kind Regards Mike
Yep, that's correct. I'm sure you can do it, you've already been shading.
| Quote:
Kind Regards Mike
| Water or Oil? | Harry C | Wood Finishing and Painting | 3 | 09-22-2010 07:27 PM |
| water splashs and water using resins | Terry | General Wood Carving | 5 | 12-14-2009 02:18 PM |
| I'm in a bit of hot water... | MDWine | Off Topic | 5 | 05-09-2006 09:23 PM |
| Over water/under water relief carving | Gray_Fox | General Wood Carving | 3 | 11-22-2004 06:57 AM |
