Go Back   Woodcarving Illustrated Message Board > Members and Magazines > Welcome Members
Welcome Members
Old 01-21-2005, 12:05 AM
Cut_Fingers's Avatar
Question A question about cutting glass - if appropriate!
I think BobD said this forum could ask questions about things other than wood carving - so here it goes.
BobD, If this is inappropriate then delete this thread.
My Lady-Friend wants to make lamps out of wine bottles. What is or how is the best way to cut a hole in a wine bottle to allow for the electrical cord to go thru the base of a wine bottle & put a bulb unit on top that would make an acceptable lamp. No, not the leg lamp. (not the Christmas movie version)
Any help would be appreciated. Just trying to make my Lady happy!
I know you gals & guys have alot of experience outside of woodcarving that may make me some extra points. So please help!
Thanks!
Jackson, MS
Old 01-21-2005, 07:37 AM
squbrigg's Avatar
Default Re: A question about cutting glass - if appropriate!
If you power carve, you have the answer in your burrs......diamond burrs will cut glass smoothly and have no ill effects on the burr. A wheel type glass cutter is too difficult to handle in a round cut, but a diamond cutting burr will work.
link to Gallery photos
Old 01-21-2005, 01:39 PM
big_Wayne_P's Avatar
Wayne
use a diamond drill bit
I had 1 i made from a Coke botte many years ago
It got broke
As Squbrigg said
The Diamond burs that you use whith power carvers should work just fine
I do not know if you have any diamond burrs or which ones you have
I would start with a small one on slower speeds and work up to the size hole I needed
Nice thing about using the diamond burrs is that by doinfg a small hole
you can use the same burr to just keep rounding out the hole till you get to the right size
Wayne P
keep on whittling & keep your knife sharp
BigWayneP51@aol.com
http://groups.yahoo.com/group/HouseOfWoodCarving/
Old 01-21-2005, 01:45 PM
Thanks fellas. I currently don't have any diamomd burrs, but I do have the power equipment. Can I get these at Home Depot or Lowes?
Jackson, MS
Old 01-21-2005, 01:51 PM
GaryMc's Avatar
Helllo,
You also can go to Lowes or somewhere and buy a glass drill bit. They are pretty expensive though. If you do, run the bit at a low rpm (200 or so) and use water a a lube. I drilled our some glass blocks this christmas with a 5/8" in hole and had some mixed results. I Broke some cause I didnt know about the slow rpm and using water as a lube.
GaryMc
When I cut myself, I bleed sawdust!
Please view my carving website
3Crosses Woodcarving
http://www.woodcarvingillustrated.co...00&ppuser=2680
3crosses51@charter.net
Old 01-21-2005, 03:05 PM
jamesfa's Avatar
cut-fingers unless you have to run the wire thru the bottle why not just get a light socket where the wire runs out the bottom side of the socket.then useing a short lenth of pipe thru a cork to keep every thing tight at the neck.
Frank
Old 01-21-2005, 03:52 PM
Wayne
Home Depot, Lowes, and even Wal Mart
will carry a few of the diamond burrs
They carry the less expensive ones
but should do the job
Look in the area where the Dremel tools and
supplies are
I saw 2 in a package at Wal Mart
the other night less than $7
Wayne P
BigWayneP51@aol.com
Old 01-26-2005, 06:22 AM
Hugh's Avatar
http://cgi.ebay.com/ws/eBayISAPI.dll...951216190&rd=1
Hi, just noticed this posting, and am interested in cutting glass. Didn't think much of using my good quality diamonds to cut a bottle, so I went to e Bay and searched for diamond bits. This is one set. "BUY NOW 7.49", 30 pc set. This set is closing in 5 or 6 hrs, but there are lots of these sets listed. Diamond drills listed in the same section.
http://www.FeathersInWood.com
& If you meet me and forget me you have lost nothing, If you meet Christ and forget Him, you have lost everything.
Old 01-26-2005, 07:59 AM
squbrigg's Avatar
Cutting glass wouldn't effect your diamond burrs, glass is soft to a diamond and wouldn't take an edge off, if that is what you're concerned about. Diamond burrs are made using real industrial grade diamonds, and should last quite a while with general use. Biggest problem is clogging and having them seperate from the adhesive that they are held by, and this usually occurs when they are run too hot.
Old 01-26-2005, 08:04 AM
Plain_Ol_Ed's Avatar
If she is going to run the cord through the hole, make the hole oversize and use a rubber grommet to keep the glass from abrading the cord. Any Radio Shack or Auto Parfts store (among others) will have grommets.
e.v.olson@att.net
Knife Collection
Try Open Office, It's Free
http://www.openoffice.org/
Glass Display Domes Where To Find? Mottles General Wood Carving 7 10-05-2006 12:20 AM
A glass painting. Shimmy Wood Finishing and Painting 0 08-18-2006 04:38 PM
Cutting out wood Kenny_S Off Topic 2 01-15-2006 02:28 PM
Glass eyes wbeery General Wood Carving 3 03-28-2005 05:09 PM
Cutting down an edge ah_chip Relief and Chip Carving 10 09-09-2002 01:18 PM
Santa Carving Contest
