Well! In my continuing sage of the tadpole pond today turned out to be a true Perils of Pauline episode. I got down this morning about 9AM to feed the fish and then, of course, the tapdoles. That's when I discovered the disaster that had struck the little pond ...
The last week to ten days it's been very hot here in Maryland, in the high 90's and very humid. But yesterday it hit over 100. The temperature had risen in the small pond over this time period and this morning I found many of the remaining tadpoles had perished. I have been adding three or four BIG watering cans of pond water to the small pond each day to add a little extra oxygen but obviously it was not near enough.
So ... dropping the feed can I grabbed my net ... scooped out everyone that I could, which, unfortunitaly, was not that hard to do ... and uncerimoniously dumped them into the big pond. It's a sad situation when you tadpoles are sooooo hot that you can scoop them out with your hand! I turned up the filtration and may do a partial water change tomorrow.
The little pond is only about 15" deep in the center where the big fish pond is over 24" deep - that means it's also about 15 degrees cooler and has the filtration. I think some will live, maybe! I even moved the batch of new eggs ... that probably did them in if the heat hasn't.
So, if you think about it tonight ... put out a pan of cold water on your deck, front porch, under your shade tree, where ever. It's hot, we're hot, and they are hot TOO! Maybe even a bread crumb.
Thanks for listening
Susan
And, yes, before anyone says it outloud I will. It's totally ridiculous for an "adult" to be so stressed over a stupid batch of tadpoles ... but I am.
