seasoning wood HoBo style With a few simple steps you can have your own stock pile of qty carving wood.
#1 Immediately after cutting or picking up your green wood seal the end grain with wax,glue,paint etc
#2 I always spray my wood with a miner borer killer or use a powder mixed with water to prevent bugs and worms in the wood.Always read the label.
#3 Get the wood off the ground, cement blocks, bricks, etc make sure the to store the wood were it gets good air. storing wood in a damp basement is a bad idea.
#4 stickers 1/2 '' thick will do place directly above one another 12 to 18'' apart to avoid bending of the carving stock and have good air flow while seasoning.
#5 Cover the wood from rain . as a rule of thumb 1'' per year air drying .
If space is in question or if you have a few small peices of carving stock you can make a kiln using plywood and styrofoam make a box the size of your choice install the foam inside the plywood box and incert a small fan and one light bulb into the box this works great having a moisture meter for this works nice .
Carve it Dont scrach it!!
HoBo
