| Carving Wood & Materials |
04-20-2006, 08:35 AM
|  | Senior Member | | Join Date: Feb 2006 Location: Wichita,Ks
| | Protective wax on wood After removing a piece of wood from a block of burled maple I now have the remaining block about 3"x4"x5". The wood was/is covered with a protective coat of some kind (feels like wax but not very thick, just a film really) now on only five sides. I got the wood at a Wood Craft store. I probably will not use any more of it for a while and I'm concerned about the block spliting. I know there is somthing I can/should do to prevent this. Any suggestions please? |
04-20-2006, 08:41 AM
|  | Moderator | | Join Date: Feb 2003 Location: Thornton, Ontario, Canada
| | Re: Protective wax on wood If the block was only coated on five sides it was to let the moisture leave the wood from the part that was not sealed. If the wood is now really dry I would think that it is not likely that it will check. Even so what is the alternative what else are you going to do with it. I would carve it and remove the protective coat. If it does check you could fill the cracks. Also when you are finished carving for the day put it in a plastic bag that will stop it from checking.
Colin |
04-21-2006, 06:15 PM
| | Re: Protective wax on wood Colin,
I cut off the one end of the block is the reason the end is unfinished. I probably won't use anymore of the wood for several weeks if not months. |
04-22-2006, 01:40 AM
| | Senior Member | | Join Date: Apr 2005 Location: TN and FL
| | Re: Protective wax on wood My guess is that it was covered in Anchorseal, a water soluable wax, sold by Highland Hardware in Atlanta, highlandhardware.com . It will wash off with hot soapy water. It's $14.95 a gallon and is an end grain and green wood sealer. Great stuff! I use it all the time. You can carve right through it too. A gallon goes a long way...but I buy it by the 5 gallons for $54 I believe.
Wade |
04-22-2006, 01:41 AM
|  | Moderator | | Join Date: Dec 1969 Location: central la
| | Re: Protective wax on wood coat the end with parifine.... canning wax if your concerned or just wrap it with wax paper... it should fare just fine.
becuse i live in a dusty area, i wrap all my basswood in waxpaper if im not going to carve it any time soon, i also boil some water in a small saucepan and use the saucepan bottom to seal the overlapping waxpaper to close the folds. like the way loaf bread use to come this way years back when the milk man dilivered. |
04-23-2006, 07:26 AM
| | Re: Protective wax on wood Thanks for info. I'll have to pick one of the suggestions and go with it. I sure don't want the $30 piece ruined. |
04-23-2006, 12:18 PM
| | Member | | Join Date: Feb 2005 Location: MI
| | Re: Protective wax on wood I have used reagula canning wax and it worked and I have also used polyeuthiene as well and it worked. I think Diamond will is so stressed with all the twist that is will crack no matter what you try. I have some 5 " diamond willow and it still fractured anyways even after sealing it. | | Thread Tools | | | | Display Modes | Linear Mode |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are GMT -4. The time now is 03:58 PM. | |
