Henry Taylor Tools
Old 05-13-2009, 01:46 PM
RUssL.'s Avatar
Default Drying small cherry logs
I have a couple of 18" long X 4" in diameter cherry logs, with the bark still on them, that I want to dry and keep in log form with minimum checking or other drying-damage artifacts.
I plan to seal the ends with Anchor-Seal (two previous pieces that I did not do this to split nearly end-to-end when they dried too fast)strip the bark off and let them dry in my unheated garage.
Anyone have any other suggestions regarding air drying small logs so that they don't split when it comes times that they have dried and are ready to carve?
Thank you in advance,
Russ L.
Old 05-13-2009, 02:43 PM
Claude's Avatar
Default Re: Drying small cherry logs
Just a thought, as I've never tried this, but...
How about putting a radiator clamp on each end, cinched down tight, and then retightened every few days as the log begins to dry?
My ETSY shop: Claude's Wood Carving
My Pinterest Page: Claude's Wood Carving and Beadwork
Old 05-13-2009, 04:34 PM
xsailer's Avatar
I guess, it was "Just a thought".
Not much of one but none the less "a thought".
You need something to do.
Old 05-13-2009, 04:39 PM
Send a message via AIM to sitesby Send a message via Yahoo to sitesby
I dried a few pieces of maple the same way and with the same results. I was told by another woodworker to never strip the bark off. By doing so you allow the moisture to escape the sides of the log to fast causing severe splitting out the sides.
Coat the end grain, leave on the bark, and let nature take care of the rest.
This has worked for me with the only problem being waiting on it to dry.
Good luck.
Jerry Hartzell
Wood Carver Hobbyist
The Blog of Jerry Hartzell
Old 05-13-2009, 05:37 PM
Sharon of the Dell's Avatar
MyMother'sDaughter!
I posted a while back about drying some cherry and plum in unused kitty litter in a cardboard box.the sizes ranged from about 4 inches down to an inch.I peeled the bark off all of it.The ones I sealed with wax on the ends didn't check or split, the rest split right down the middle.I think they have been in the boxes for 4(?) or so months.the larger pieces probably only have a few more months till they are dry enough. the small ones, I would say are just about ready to be carved into something.All in all I think its a half way decent way to speed up the drying process.
Old 05-13-2009, 10:16 PM
RUssL.'s Avatar
Thank you all for your input.
I guess I will leave the bark on and put it in the warehouse at work where I was able to dry 2 1/2" X 8" X 10' basswood planks in less than six months. The place is more than bone dry.
All the best,
Russ
Old 05-14-2009, 09:28 AM
Claude's Avatar
No - it's the other way around, Bob. I was taking a break from some intensive concentration on a large, complex, spreadsheet I've been working on, and was just giving my mind free range for a couple of minutes...
Old 05-14-2009, 02:37 PM
a non-mannerist
Latex paint doesn't offer much of a barrier to moisture migration.
Paraffin wax is the best. Three coats of paraffin wax blocks moisture almost 99.9 % (test results from USDA Forest Products Lab study)
My Gallery
Old 05-16-2009, 09:45 AM
Just because a small log doesn't split, doesn't mean there isn't enormous tension in there. It may split badly after you start carving. I had a walking stick blank (hickory) that dryed for a year just fine. Then I peeled the bark and it promptly split.
Old 07-19-2009, 05:45 AM
The kitty litter idea sound good for small stuff ---But for Paraffin I wonder if when you take off the bark should you cover it's sides as well as the ends? My wood is Cherry wood fresh cut yesterday, If I could I would try to carve it while it is green, I understand is is easier to shape ---how long would you classify the wood green? Just newly cut or up to 6 months aged? Thank you, I am quite the newbie
Need advice on drying basswood logs chipper67 Carving Wood & Materials 2 12-05-2011 10:53 AM
logs,need help Dileon Carving Wood & Materials 14 02-20-2011 01:13 AM
Drying Logs Mudbone Carving Wood & Materials 7 07-26-2009 04:18 PM
How to deal with fresh cherry logs meipo Carving Wood & Materials 31 07-19-2009 05:30 AM
Carving and Drying Cherry Guest Carving Wood & Materials 2 12-27-2004 11:51 PM
