Old 07-07-2002, 09:32 AM
Mike
Guest
Posts: n/a
Default Dry wood problem solved!
My wife gets credit for this one. I have a problem with my wood getting too dry which causes lots of carving problems. As we were cleaning out the garage, my wife pulled out a styrofoam cooler.
Some empty margarine tubs, a cup of water, and problem solved!
Old 08-08-2002, 12:00 AM
Big_Sid
Guest
Posts: n/a
Default Re: Dry wood problem solved!
I assume you put water in the tubs and then keep your wood in the cooler with the lid closed. Does it mold if left too long? How long can you leave it in there?
Old 08-08-2002, 08:50 PM
Guest
Guest
Posts: n/a
If your problem is that the dry wood is too hard to carve, spray it with a 50/50 mixture of alcohol/water. Use regular rubbing alcohol. Don't use Jack Daniels as you will be tempted to drink it instead of spraying it... that won't make the wood any easier to carve, but you won't care!
If the problem is with the wood splitting, you could also sprau it with water and put it in a garbage bag. Keeping it in the refrigerator will prevent any mold.
Old 08-09-2002, 03:42 PM
MikeD
Guest
Posts: n/a
I have had a small problem with leaving the wood too long in the cooler. I left a carving I am working on in the box for six days and it warped. Nothing serious, but it could have been if it were another piece. I have found two to three days to be a good number.
Yes, you do put water in the box, the tubs are to keep your work out of the wter, and no, I haven't had any problems with molding. GL.
Old 08-27-2002, 04:36 PM
Guest
Guest
Posts: n/a
??? what state are you in, I'm at 8500 feet in the Rocky Mountains and dryness in the wood is a BIG problem here!
Problem Terry Vance Message Board FAQ, Suggestions and Feedback 0 12-27-2006 07:07 PM
A Problem Dylan Publisher Feedback 3 07-07-2006 07:45 AM
Help with a problem Joseph Slive Relief and Chip Carving 11 11-10-2005 10:02 AM
Bass wood problem Chahlie General Wood Carving 23 01-12-2005 09:19 PM
Is anyone else having the same problem Colin-Partridge General Wood Carving 11 12-03-2003 07:05 AM
