Old 01-19-2012, 08:56 PM
Default water/alcohol prep
Hello all:
When using a water/alcohol prep for carving on old dried wood, I have a couple questions:
What is the purpose of the alcohol?
Does it matter whether I use a rubbing alcohol, isopropyl alcohol or denatured alcohol?
Should I soak the wood, thoroughly wet the surface or just lightly mist the surface?
How often should I apply the mixture?
Thanks for your help.
http://JerryLWatson.Wordpress.com
http://theantiquarianchronicles.blogspot.com
hubpages.com
Old 02-03-2012, 12:50 PM
Default Re: water/alcohol prep
Often when I am carving older basswood, I use a 50/50 mixture of isopropyl alcohol and spray it on. Depending on the dryness of the wood I find that I may have to really "wet" the wood. Sure makes the carving easier. Dries quickly as well. Good Luck.
Rob Wilson
roberttw@rogers.com
Old 02-03-2012, 03:13 PM
That's what I wanted to know. Thanks, Mr. Wilson. I've got a block of basswood that was one of the first ones God made and it shows when I try to carve it. I did try rubbing alcohol and water but it didn't do a whole lot unless I soaked the wood which just got spongy. I'll try isopropyl alcohol instead. Appreciate it.
Old 02-27-2012, 01:23 PM
I use the mix on missouri bass wood it works well -------------Jack
Old 02-27-2012, 02:16 PM
Thanks for your advice, Jack.
Jerry
Curing walkingstick with denatured alcohol? Nąth Stick and Cane Carving 1 02-28-2010 04:15 PM
food safe, alcohol proof finish shawshank70 Wood Finishing and Painting 1 11-03-2009 08:36 PM
alcohol and ammo papasar Off Topic 7 10-22-2009 02:00 PM
Over water/under water relief carving Gray_Fox General Wood Carving 3 11-22-2004 06:57 AM
