Old 12-09-2011, 05:22 AM
Default Using Cooking oils on wood
Hiya,
First post so please be gentle Hopefully i have attached a photo of a carving i have just finished for my wifes christmas present. I was hoping for a little help and advice on the best way to finish it. i dont want it to have a glossy varnish and wanted to keep it natural looking.
i have heard you can use vegetable/sunflower oil to coat the wood in for a protective coating. is this true?
any help i can get will be gratefully recieved
Thanks
Paul
Old 12-09-2011, 07:52 AM
Default Re: Using Cooking oils on wood
Crafty, I wouldn't advise any type of cooking oil to finish with, it will go rancid. If you want a satin finish maybe try pure tung oil. Easy to apply and it will give the desired outcome.
My WCI Gallery http://www.woodcarvingillustrated.co...y.php/cat/1096
Old 12-09-2011, 08:24 AM
North of 49
Thats a nice piece. Mineral oil will also work and won't turn rancid.
Old 12-09-2011, 08:34 AM
Thanks for the advice. cooking oils DID sound a bit weird to me. i think someone was just winding up the newbie carver. Im still trying to find that left handed screwdriver they asked me for too
Old 12-09-2011, 10:16 AM
Location: Morrisonville, N.Y. ,near N.Y.,Vt., Quebec border area
How about boiled linseed oil. BLO has a soft look and feel when dry. Nice carving and welcome to the forum.
Carve On,
Kadiddle
Old 12-09-2011, 10:45 AM
Claude's Avatar
BLO or Tung oil are often used for an oil finish to protect the wood, then followed up with some wax after the oils have "dried". BLO and Tung oil, also Danish Oil, contain chemicals to help the oils catalyze or dry quicker. Waxs can be as simple as using some floor wax you already own, to special purpose waxes. I've heard that a mix of beeswax and carnuba is good. You could even use some non-colored furniture polish such as the lemon oil one.
As to the food oils (vegetable, olive, walnut, safflower, etc.), I would not put these on a sculpture - as Dan says, they'll go rancid over time. Mineral oil won't go rancid, but it won't dry like BLO either. For cooking/eating spoons, food bowls, etc., that are used for food all the time, the food oils or mineral oil are fine. BTW, get the food-grade mineral oil from the pharmacy, not a DIY store. I use olive oil on my spoons and spatulas that I cook with because I use olive oil in my cooking.
My web site
Old 12-09-2011, 12:33 PM
Crafty: First, that's a great carving with the sweeping curves. How tall is it?
May I put my biochemist's hat on for a moment? Follow Claude's advice and that of the other posters. Vegetable oils won't dry dry, they'll go dry-sticky and collect dust that you can't get off. Since your carving does not look to me like any kitchen appliance that I've ever seen, use some treatment really intended to seal and protect wood.
From time to time, I regret slopping olive oil all over several chopping boards that I use quite often. There's a grime that builds up, despite washing that I can only scrape off with a metal straight edge.
OK. Hat's off to you.
Old 12-09-2011, 03:08 PM
chipmunk's Avatar
if i want to do a piece and dont want to change the color but want to add a finish or protection i use clear acrylic if u put 2-3 thin coats on it it will look like it has NO finish on it try it on scrap first of the same kind of wood to see if its the look u want its a lite finish so it can be dusted and help keep moisture out of it all other finish will change the color of the piece that i know of all the varnishs,oils even some waxs will
Old 12-09-2011, 07:02 PM
Freshly split slabs of Western Red Cedar really are an amazing lipstick pink. Within 30 days, that changes to a drab yellow/brown which looks like Hello when finished with clear acrylic. Bug-wood pine has the characteristic blue-grey of the fungus that the beetles carry with them. Raw wood with bands of color look really attractive. I made a bunch of kitchen storage & shelving units with it. Finished with clear acrylic, the wood looks just plain finger-grime dirty.
Chipmunk's lesson = test a piece first.
Old 12-10-2011, 02:57 PM
Wow, i didnt realise i would get this many responses. Ive learnt so much with my first post already. Thanks so much for all your help.
For Robson Valley, thanks for the compliment, its around 7" or 8" high. It was a scrap of wood i found at work, no idea what sort it is.
Hand oils on wood jgs795 Wood Finishing and Painting 8 12-07-2011 11:04 PM
Thinning out oils ????? tm5825 Wood Finishing and Painting 3 12-26-2010 12:18 PM
A video tribute to oils: W.duBois Wood Finishing and Painting 15 12-14-2010 08:24 PM
Oils and finishing Curtis The Carver Carving Wood & Materials 2 11-07-2010 06:37 PM
Artist Oils K. Ellenburg Wood Finishing and Painting 7 03-15-2008 02:54 AM
