Old 02-22-2008, 02:11 PM
Default Turpentine + linseed oil a good idea?
Hi!
I used to paint pictures with oil colors and the general method is: use a lot of wood turpentine to dilute the first layer of paint, and on subsequent layers, use less and less - until the final layers, which are painted without adding any turpentine. Turpentine makes the oil colors dry faster - they're based on linseed oil.
Now I thought of trying the same method for finishing wood, only without the color: first apply linseed oil, heavily diluted with wood turpentine, and adding more oil to the mixture for subsequent layers, until for the final layer using oil alone. Is this a good idea, or does the turpentine harm or color the wood, or are there any other side effects?
Old 02-22-2008, 04:44 PM
Keoma's Avatar
OnlyBoringPeoPleGetBored!
Send a message via Yahoo to Keoma
Default Re: Turpentine + linseed oil a good idea?
I tried this once as a suggestion from a friend. It worked really well and gave my wood a nice, natural antique glow. The smell takes a bit to dissipate, but if that does not bother you...thn I say try it. Besides you smell enough of it...not much will bother you...lol
Art Inspired By Nature and Crafted from 100% Salvaged Local Hardwoods
Haircombs, Hair Sticks and HeirLooms
All women are beautiful...naturally!
Old 02-22-2008, 04:48 PM
Thanks Keoma - how many times did you apply the mix, do you happen to remember?
Old 02-22-2008, 05:02 PM
squbrigg's Avatar
I use a mix of Boiled Linseed Oil, Turpentine and Gloss Spar Varnish on my canes, as many layers as I can. Gives them a nice soft finish and easy to maintain. Hand rub it in too, as a final wet sanding, using the mix as a lubricant.
link to Gallery photos
BLO Boiled Linseed Oil everything you will ever want to know groozier Wood Finishing and Painting 224 05-15-2008 07:52 AM
Linseed oil finish paul_guraedy Wood Finishing and Painting 5 11-08-2004 06:42 PM
Boiled Linseed Oil - where to buy rocket39 General Wood Carving 20 11-03-2004 09:33 AM
Santa Carving Contest
