Dale Green Woodcarving
Old 03-21-2009, 09:59 PM
Phyllis Singer's Avatar
Old Bat with a knife
Question Tung Oil finish
Hi Carvers, I finished a bull moose today and it is Butternut. I put a coat of Tung Oil on it. How many coats are enough? And should I spray a coat of clear semi-gloss wood finish afterward?
Thanks I'm still just trying to learn,
Phyllis Singer
Old 03-22-2009, 01:09 AM
Al_Hillis's Avatar
Default Re: Tung Oil finish
Hi Phyillis , if you post your question under the heading of Wood finishing and painting you should get lots of answers to your question
http://picasaweb.google.com/al.hillis/WOODCARVINGSMINE
Its better to take two steps forward and one step back then never having danced at all
Old 03-22-2009, 08:00 AM
Paul_Guraedy's Avatar
I use tung oil on my natural finish carvings (and on our natural finish furniture). How many coats? It depends on the look you are seeking. Tung oil is diluted with mineral spirits to varying degree (based on manufacturer). So, the more you put on there the higher the gloss on the carving.
I use Formby's low gloss tung oil (not the tung oil finish which has other things in it). Make sure to let it dry well between coatings and I like to go over the first couple of coatings with a light rubbing of at least OOOO steel wool. Then use a clean cloth to eliminate any small pieces of the steel wool. I would use at least 2-3 coats and I allow a drying time of 24 hours between them.
Be sure that you allow any cloths you use for tung oil to air dry in a non-flammable place. Tung oil has the potential for self-ignition. Once they are dry they are safe and can be thrown away.
Paul Guraedy (jer-AH-dee)
padi.guraedy@gmail.com
My Website
www.guraedy.com
When all the trees have been cut down, when all the animals have been hunted, when all the waters are polluted, when all the air is unsafe to breathe, only then will we discover we cannot eat money.
~ Cree Prophecy ~
Old 03-22-2009, 11:59 AM
Paul--I was admiring your eagle head. Is that painted with acrylic paint? What sealer do you use? I carve mostly with basswood and paint with acrylics and use a semigloss sealer. I've never tried any other combination. Do you use tongue oil on acrylic?
Old 03-22-2009, 12:39 PM
Larry Marshall's Avatar
It's important, when discussing tung oil finishes to be explicit about what product you're using. There's a big difference from using 100% tung oil and something like Formby's Tung Oil Finish, which is really a oil/varnish mix. These oil/varnish mixes will build much more quickly than thin coats of pure tung oil. They dry much faster as well.
Cheers --- Larry
www.woodnbits.com
www.woodnbits.com/blog
Old 03-22-2009, 01:45 PM
Thank You Al, Sorry I posted on the wrong forum
Phyllis
Old 03-22-2009, 01:48 PM
Thank You Paul. I used Waterlox Original, made from tung oil. I did a lot of detail on the hair on the moose so can't really rub out the finish. Is it OK to just spray Deft semi-gloss over it now?
Phyllis
Old 03-22-2009, 01:51 PM
Thanks Larry, I used Waterlox Original. I did a lot of detail on the moose's hair so can't really rub it out. Is it OK to spray Deft semi-gloss on it now after it dries?
Phyllis
Old 03-22-2009, 05:16 PM
Larry, I agree about the pure tung oil. There are not too many places around here to get 100% and then, if you want it to dry in the next year or so, it needs to be mixed with mineral spirits. That is why I use Formby's tung oil rather than the Formby's tung oil finish. I did use a lot of 100% tung oil on the ceiling boards in our house. Grizzly sells it by the gallon and we cut it with mineral spirits at about 1:4 and that made the tung go a lot further also.
I painted the eagle head with gouache which, as near as I can tell, is somewhere between watercolor and acrylic. I have been told that the watercolor white is not very permanent. I use winsor newton and mixed the gouache white with a little watercolor ivory black to get the color I used. Just mixed it by sight so do not know the ratio. I then coated the carving with several coats of Krylon matte finish.
My Website
www.guraedy.com
~ Cree Prophecy ~
Old 03-22-2009, 08:21 PM
Ain't that the truth!
Cheers --- Larry
Cheers --- Larry
www.woodnbits.com
De-glossing a tung oil finish? scooter Wood Finishing and Painting 6 04-27-2012 01:49 PM
Tung Oil ddt Wood Finishing and Painting 4 01-26-2010 06:12 AM
Tinted tung oil or WDO mik1947 Wood Finishing and Painting 2 01-30-2006 02:02 PM
Pure tung oil Paul_Guraedy Wood Finishing and Painting 5 12-29-2005 04:41 PM
Tung Oil groozier General Wood Carving 11 03-05-2004 12:34 PM
