Re: tung oil application I use tung oil all the time on wood projects (no time for carving now). I like Formby and you can purchase it in High Gloss or Regular finnish. As far as applying multiple coats, it depends on the humidity, type of wood, and how much sunlight it will get. It will soak up fast but if you oversaturate it, the piece becomes sticky and attracts dust while drying, then you have to buff it out. Furniture that sits under a window like a dresser, I put 5 - 7 coats on it and the kids can beat it up with no problems and the sun fades it with 1 or 2 coats. It almost has the durability of polyurethane. If using High Gloss, you need to wear sun glasses with 5-7 coats.
Tung oil over bare wood is also a nice finnish, or you can put it over a light stain. You get best results when you give it time to soak in; if its tacky to the touch you're wasting it by applying the extra coats. After about 20 -30 minutes I'll get a soft rag or foam applicator and sometimes hand rub it with my fingers, just adding a tiny amount to avoid the tacky streak marks. Then I let that coat sit 24 hours.
__________________ Humor Heals and when spread can be infectious. |
