Old 03-01-2009, 09:51 AM
Richard R. Boyd's Avatar
Spudlix
Default Tinting Linseed oil
I really like the effect of linseed oil applied directly to bass wood but sometimes I would like a slightly darker petina. My question is, what should I use to darken linseed oil?
Spudlix
Old 03-01-2009, 10:42 AM
fortysomething's Avatar
Default Re: Tenting Linseed oil
I have used artists oil paint to tint linseed oil. The mixture that I learned (I can't recall the source) includes linseed oil, turpentine and artists oil paint. I have used this as an 'antiquing' finish on carvings.
Old 03-01-2009, 10:46 AM
arttimes
I use oil paint. I already have the paints (I paint on canvas) so I don't have to purchase them, but depending on the color you want- for instance a warm brown you could probably use burnt umber, and depending on how much color you want, you adjust the amount of paint you add. It's better to start with just a little, you can always go darker.
Hope this helps, Sandra
Old 03-01-2009, 10:51 AM
arttimes
I have never mixed turp with it for staining something. I would think it would make it too thin. Did that work well for you fortysomething? Might be something I'll have to try. I think I would use the odorless mineral spirits though, the smell isn't as bad.
Old 03-01-2009, 11:05 AM
It seemed to work well. The turp helped to act as a drier for the finish. I have used it more as an antiquing finish over painted or color washed work. Mineral spirits work well too!
Old 03-01-2009, 01:30 PM
Spudlix
Default Re: Tinting Linseed oil
Thank you Forytsomething and Arttimes for the help. I knew I had read something, some time back, about mixing color with linseed oil but I couldn't recall what type of paint was recomended.
I will get some oil based paint for color verity. This thought occured to me, I have oil based stain waqlnut, fruitwood etc. do you know if oil based stain can be used with any hope of success?
Thanks again.
Spudlix
Old 03-01-2009, 02:24 PM
Iowa Carver's Avatar
Knife Nerd
Besides using oil paint you can simpley use some oil wood stain mixed with the blo. Most wood stains are just ground pigment in boiled linseed oil.
Corey
Visit My Website at:
http://theiowacarver.blogspot.com/
Friend My On Facebook
Old 03-01-2009, 02:43 PM
Spudlix
Thanks Corey,
That sounds great. I will try it.
Spudlix
Old 03-01-2009, 04:21 PM
aulddiy's Avatar
I tried blo and brown acrylic mixed on a wood spirit. Wiped the highlighted areas with a cloth. The next day I put another touch of the mixture on to darken some areas. A red coulered pencil finished it off. I liked the results . I would n't use it on caricatures but I think I'll try it on something else.
Old 03-01-2009, 04:43 PM
Mark N. Akers's Avatar
I use BLO and Artist Oil paint tube Burnt Umber,I squeeze out 1" of paint per Quart of BLO,make sure you use Boiled Linseed and not Raw,it will never dry.
Linseed oil (not boiled) ? toycarver Wood Finishing and Painting 29 12-29-2011 06:43 PM
Yellow Linseed Oil revnate Wood Finishing and Painting 7 01-01-2009 10:14 AM
Boiled Linseed Oil Pablo Wood Finishing and Painting 10 12-28-2008 02:14 PM
Boiled Linseed Oil Simplyme Wood Finishing and Painting 5 09-29-2008 02:31 PM
Boiled Linseed Oil - where to buy rocket39 General Wood Carving 20 11-03-2004 09:33 AM
